Throttle sticks after intake cleanup
Old Aug 14, 2002 | 07:44 AM
Steve89GTA's Avatar
Hi all. I just used a bunch of that throttle body cleaner stuff and sprayed it into the intake. Afterwards, I noticed right away that the throttle now 'sticks' and I have to blip it to bring it down. WTF, does anyone know how I can fix this? Should I install a helper spring on the throttle body?
Old Aug 14, 2002 | 09:23 AM
rezinn's Avatar
Oil up the throttle blade?
Old Aug 14, 2002 | 09:29 AM
Steve89GTA's Avatar
I've tried Wd40 all over the spring, linkages and cables. Everything is nice and clean.
Can you be more specific? Is there something to lubricate inside the throttle body?
Old Aug 14, 2002 | 02:23 PM
rezinn's Avatar
WD-40 sucks as a lubricant. I would put motor oil on the sides of the throttle blades and on the linkage, wherever it could stick.
Old Aug 14, 2002 | 02:27 PM
Steve89GTA's Avatar
Cool, I try that for the external parts. Don't like the idea of oil inside the throttle body though.
Old Aug 16, 2002 | 04:34 PM
xformula79's Avatar
sticking
Whenever I do a tune up on a TPI car, I always take off the throttle body, tear it apart and clean it with a solvent such as thinner or spirits that removes tarnish very easily (AIC valve must be removed before cleaning). You might try spraying some WD409 on the throttle cable also.
Old Aug 16, 2002 | 05:23 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I have this same problem....the idle will be a bit high (bout 1000rmps) and I'll have to blip the throttle to get the idle down. now if the accelerator cable is off, the throttle will return to where it's supposed to be everytime....snaps right back into place....so it seems as if the accelerator cable is what's keeping the idle high. I've cleaned it, greased it, etc...any ideas anybody?
Old Sep 4, 2002 | 02:29 PM
Kevin Johnson's Avatar
Aside from the comments on the most recent thread discussing this, you might want to buy a motorcycle cable lubing tool. It will allow you to inject lubricant into the cable without having to pull it out of the vehicle.
Here's one possible supplier, but it wouldn't be too difficult to make one up yourself:
http://mcparts.com/runningchems.html
Cable Life Lubricant Kit $15.95
Cable lube and pressure lubing tool.
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
