Runner Q: please help!!!!
Old Aug 14, 2002 | 10:55 AM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Last time i ask and i hope i´ll get my answears!!!
I have a almost stock GTA 350 -90 that has k&n air filter +catback.
I´m intending to buy headers and porting the plenum + afpr.
This is all i'm gonne do on the engine, exept and here is my question!!! is it worth buying runners for my setup cause i can buy a set of as&m a little cheaper or should i save the 400$,
i´m not gonne buy any base or cam or heads in the future.
THANKS !!!!!!!:hail:
Old Aug 14, 2002 | 11:58 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The intake base would be a lot more useful than runners. As would a cam swap.
Old Aug 14, 2002 | 01:45 PM
CamaroX84's Avatar
If you're going to spend around 400 bucks, I would suggest buying a base instead of the runners. You can get a decent Edelbrock one for cheaper than that, and I think it would help you much more. The stock base is much more restrictive than the stock runners. Hope this helps.
Old Aug 14, 2002 | 03:15 PM
DOOSKI's Avatar
Transmission: A4
So what you are saying is that the runners will do nothing to increase my performance at all with my setup. ok thax for saving 400dollar. it´s too much work too swap a base.
Old Aug 14, 2002 | 04:30 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Huh? You have NO place to do a quick manifold swap? Bummer.
Old Aug 14, 2002 | 10:06 PM
Ed Maher's Avatar
Car: 04 GTO
In all seriousness, on abasically stock set up, runners are worth 2 tenths at best. The base is the worst part of the stock TPI intake for sure.
Old Aug 15, 2002 | 10:54 AM
tpi_roc's Avatar
Im still running stock runners...
Im not proud at all but my car did 14.1 like that.
Old Aug 16, 2002 | 08:59 AM
DOOSKI's Avatar
Transmission: A4
do you think 2 tenths are worth 400dollar!!!
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
