MAT sensor relocation?
i have heard of several guys putting thier mat sensor in the air box for a cooler reading. is there any performance gain to this? is it worth it to go ahead and do it? what does this do for the car? thanks
Car: Death Mobile
Engine: 666 c.i.
A relocate MAT/IAT does NOTHING on a MAF car. The MAF measures the air flow for ALL fuel calculations. Any changes in air temp is detected by the MAF, NOT the IAT/MAT.
The IAT/MAT on a MAF car is solely for enabling/disabling the EGR, so all you will do is affect the operation of the EGR. Save your money.
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
Re: MAT sensor relocation?
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"what about a MAP car?"
I have had this discussion with the local guys here in our TPI club. My thought is the factory tables in the ECM are set up for the location to be in the plenum. If you relocate it to a location in front of the throttle body then IMHO you would have to go back in a change the tables. I would like to hear other opinions on the subject.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Thanks.
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
In theory if it did indeed add more fuel, it would made more power (best af ratio is 12:1), but 14.7 is the "best" for reduction in NOx emissions, and that's why we run that normally.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/post...35-post17.html
No different than what the factory did on early cars .Purge and PCV on same line
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Opinions vary
https://www.thirdgen.org/forums/tech...mp-sensor.html
That's why I said "in theory if it did", not implying it did, not implying it didn't.
So I was right on the ball last year. You did it again vetteoz. Thank you. I just never got a concrete answer on my idea of tapping the EVAP Canister until now.
You already worked out best way last year.
Engine: 4++,350 & 305 CIs
You can relocate it to the air box like I did on all my cars, just make sure its in the flow of the air..
Will it make more power? Not really anything even a dyno will pickup.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
So what about using the V6 sensor in the V8 location (in the plenum) ? Would that not give a more IAT reading, for a speed-density car?
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
88, air, gains, iat, irocz, location, make, mat, matthirdgen, relocate, relocated, relocating, relocation, sensor, temperature, tpi
