Stealth Ram problems
Old Aug 24, 2002 | 03:23 PM
Jasper89ROC's Avatar
Since the new intake sits back further, the intake w/ the maf on it is too short, I cannot tighten down the end on the throttle body and tighten the bolts where the filters are or else the TB end falls off , i need about 1/2 more space so they can both connect. Any one else have this problem?
How did u fix it?
-Mark
Old Aug 24, 2002 | 03:42 PM
Jza's Avatar
Jza
Stack some gaskets or if you're made of money get one of those TB spacers.
Otherwise, you're going to have to fab up your intake tract.
Old Aug 24, 2002 | 03:47 PM
Where do i buy a TB spacer, is there any problems w/ vacuum leak. If I dont figure out something else I will need to get a CAI which will cost more $$$
-Mark
Old Aug 24, 2002 | 04:35 PM
Jza's Avatar
Jza
There's no true "vacuum" in front of the throttle body. That only exists behind the throttle body. For everything in front of the TB, you're just concerned with metering every bit of air that goes through the MAF, and that all the air entering the engine has passed through a filter.
As far as the spacer, do a search for Helix or Power Tower or something to that effect. It's like a hundred bucks though, so you'd probably be better off just getting some ducting of your own.
Old Aug 24, 2002 | 05:02 PM
cobrakiller1989's Avatar
you cant stretch that neck that connects to the TB? the ribbed part....i just pulled on mine some and tightened down the clamp. problem solved. good luck
Old Aug 24, 2002 | 05:44 PM
I tried stretching mine too but I need like a half inch, so it will not stretch enough, I was gonna try heating it up(hot water) and see if that would help. If not Im gonna call Holley monday and get some answers.
-Mark
Old Aug 25, 2002 | 05:41 AM
88TransAMgta's Avatar
i also has to stretch mine and it fit fine
Old Aug 25, 2002 | 08:28 AM
4L60bliss's Avatar
99.9% of the time this is correct, providing there is no restrictions. Here is a link to a guy that has a Superramed 408 and was sucking his air intake flat:
http://63.99.108.154/ubb/ultimatebb....c;f=1;t=000365
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stangski09
Nov 14, 2015 01:27 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
