Looking for NON-A/C blower motor box
Old Aug 26, 2002 | 04:37 PM
formul8!!'s Avatar
Car: 2004 GTO
If you have one, know the part number for them or know a supplier that has one- please post here!!
I am yanking the a/c soon and do not want a big gaping hole in my firewall.
Thankls!
formul89@yahoo.com
Old Aug 26, 2002 | 05:32 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Good luck, I've already yanked mine and can't find one anywhere. So if you find one and no one posts here with info on where to find them please post back!
Old Aug 27, 2002 | 11:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
junkyards are a rarity. gm doesn't have them anymore. i even checked their storage company for slow moving parts and they were out.
i hear s-10's can be used.
i got mine from ebay for 45 shipped off of a camaro.
Old Aug 27, 2002 | 12:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I found one.. no, it's not for sale! A guy, I think Mark Shields, had his brother fab up a plate to make the heater/condensor box into a heater-only box.
Old Aug 27, 2002 | 01:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I cut the fiberglass AC box in half, just on the drivers side of the blower motor & fabbed & riveted a sheet metal duct to direct the air into the pass compartment. The case part# is 3056659 & the gasket is 3048270 for 84-92 models. They are both discontinued from GM.
Old Aug 30, 2002 | 06:56 AM
redrs89's Avatar
That's Funny!I have a couple of them sitting around.If ya are interested ,Make me an offer.....
Old Sep 5, 2002 | 04:27 PM
formul8!!'s Avatar
Car: 2004 GTO
WOOHOO!!
I found one in a junkyard that is 2miles from my house.
It was a b!tch to get out because of one bolt.
Not bad for $20.00 with the blower motor. The motor won't work with the harness my car has, so I will tell them it doesn't work and get my $15.00 for the motor itself back!!
:rockon:
Old Sep 5, 2002 | 06:43 PM
89ProchargedROC's Avatar
Hey, i'm pretty sure that you have to adapt you factory harness to the connector on that box because the A/C box blower motor wont work with the non a/c box.....
Email L9T8Z about it from the mfba board, he'll let you know
Old Sep 5, 2002 | 08:56 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hey,
I actually havn't gotten around to wiring mine up yet, but the problem is the A/C motor's fan is longer than the non a/c model. YOu MAY be able to swap fans on the actual motor.. Give it a whirl, or maybe I do. when it gets cold out.
which.. will probably be in a few weeks.
freaking new england.
-- Joe
Old Sep 5, 2002 | 10:56 PM
formul8!!'s Avatar
Car: 2004 GTO
I noticed that the fan is longer on the A/C model too.
Another interesting fact is the model I have was manufactured by Hurst, as in transmissions!! Has the logo molded right in to the plastic!
I'm going to check Autozone to see if they might have a non-A/C blower motor with the weather pack connector.
Old Sep 5, 2002 | 11:07 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
look!!!
heres what i did to mine.......
Attached Thumbnails Looking for NON-A/C blower motor box-copy-aug05_03.jpg
Old Sep 6, 2002 | 02:04 PM
formul8!!'s Avatar
Car: 2004 GTO
Went to Pep Boys and picked up a Siemens blowe motor for an A/C car. The design is a little different, allowing the fan from the non-A/C motor to fit.
I will be installing the box and fan tonight to see if it does work.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
soarestransam
Sep 1, 2015 04:00 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
