TPI & LT1 throttle bodies
Car: '86 Iroc-z28
What is the difference between the LT1 and TPI throttle bodies?
Cosmeticlly to the unexperienced eye they appear to be the same.
Thanks for any information,
-xmind2006
-xmind2006
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The throttle cable connection is different and the LT1 TPS is not slotted to allow adjustment. The idle air passages are also slightly different between the TB and plenums.
Car: '86 Iroc-z28
Jza,
Did you imply that an LT1 could be fitted with a 700R4 or are you implying that an LT1 throttle body can be fitted on a tpi setup?
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
like said....the throttle bodies have slight differneces...but a tpi tb can be used on a lt1 intake and vice versa i believe
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Throttle position sensor has a different connector, and they're not interchangable between the two types. Cover plate bolt spacing is different, and the LT1 '93 TB's do have the TV cable attachment point since '93 was the only year the F-body was offered with a non-electronically controlled transmission. I would reccomend making an adapter harness if you were to use the LT1 TB...order the connectors from a place like year one, or get a male triangulated 3-pin TPS connector, and a female straight 3 pin weatherpack connector. That way you lengthen the harness if you need to (LT1 intake, etc.)as well as add more of a place to set your TPS and not butcher your TPI harness. Only question is what the TPS is set at on a 4thgen Z. I think it's the same.
Car: 97 WS6 T/A
Engine: LT1 383
They will bolt on but are missing a few things, the vacumme port on the bottom is missing from the LT1 and of course the TPS is different. but the purpose and function of the LT1 TPS is identical to the TPIs the base is .45 and WOT is 5 vdc just as it is on the TPI. Use a 92 (vette only) or 93 Auto T/B soas to have the 700s cable hook-ups. the IAC is the same.
Perry
Perry
Car: 97 WS6 T/A
Engine: LT1 383
As far as I can tell the connector is identical, I'll have to look over the wiring diagrams to see if they are the same creatures though. I do know that both IACs look identical and the TPI one will screw into the LT1 T/B (have both).
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
