Head/Intake combo for tpi
Old Sep 17, 2002 | 12:22 PM
tpirocz's Avatar
Car: 89 IROC-Z & 94 Z71
Engine: both 5.7
Transmission: both autos
What are some good combos for a L98 tpi motor. im not looking to make crazy amounts of power, but id like an extra 40-50.
i was thinking about the vortec heads and intake form sdpc.
i also need to stay emissions legal...
Old Sep 17, 2002 | 12:57 PM
86IROC-SS's Avatar
Id really stay away from any TPI performance parts. Try something along the lines of stealth ram/ superram. As for heads, AFR heads seem to get good reviews. Ill be having my factory aluminum heads done by FLP (great to have them in my backyard!). It looks like having your heads done is cheaper but alot more downtime. Ill be going superram, but i wouldnt unless i was getting the deal i am. Try thunderracing.com for a stealthram setup.
matt
Old Sep 17, 2002 | 02:33 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Fast Burn heads are nice. Ligenfelter and edelbrock makes intakes for a TPI setup. SLP runners work nice. Porting will help too.
Old Sep 17, 2002 | 03:12 PM
JD68Camaro's Avatar
I dont know how much money you are going to spend but I would get the stealth ram and some 113 Corvette heads and have them ported and I would get me a good cam too.
But before I would get a stealth ram I would make sure it would pass emissions.
JD
Old Sep 17, 2002 | 04:31 PM
tpi_roc's Avatar
I just got back from the machine shop and I spent about an hour there comparing some heads just for fun, I was surprised at the lack of quality in both fast burns and AFR, I was shocked when I pitted them against some others at the lack of quality of workmanship.
ESPECIALLY the fastburns
I'd just like to put the info out there for people who dont have the means to visually compare with their own hands and eyes for themselves
Old Sep 17, 2002 | 04:43 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
What were you comparing them to? Have you personally seen a pair of pro action heads?
Old Sep 17, 2002 | 04:46 PM
tpi_roc's Avatar
I was comparing them to each other
Yea i've seen pro actions
After my little experience I would never spend my own money on:
Trickflow
Fastburn
I would have to think long and hard about:
AFR
Edelbrock
Most of this is comparing quality of workmanship with just my head knowledge of where most of them flow at..
Its pretty much undisputed that AFR does some good things with flow numbers.. But when you compare apples to apples any of the other heads could be made to catch up, but with the benifit of a cheaper price and better quality.
Pro actions i still have good faith in, they're a great head
Old Sep 17, 2002 | 06:42 PM
JD68Camaro's Avatar
You may want to look at the Pro 1 heads from Dart they are realy good and they dont cost that much but I would not go over 200cc unles you are going to make it 383 and bigger.
JD
Old Sep 17, 2002 | 06:56 PM
tpi_roc's Avatar
Dollar for dollar the pro 1's were by far the best head, both in quality and potential.
Old Sep 17, 2002 | 07:03 PM
tpirocz's Avatar
Engine: both 5.7
should i stay away from the vortec tpi set up
Old Sep 17, 2002 | 09:53 PM
tpi_roc's Avatar
man what is it with people getting names as close to mine as they can lately....
Vortecs are nice.. but the money you spend by the time you get the thing running could easily be spent on some sportsman II's or some mid level aftermarket heads.
Old Sep 18, 2002 | 07:23 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Trickflow
Fastburn
AFR
Edelbrock
Well I have had experience with Edelbrock & I am not impressed. I did a buddy's 302 Ford with Edelbrocks & found some of the rocker stud holes not drilled correctly & helicoils not installed correctly. I had to spend about 3 hrs correcting their faulty workmanship. I also had a bad intake base from them. They drilled the injector screw mounting hole crooked & into the intake port, causing a vacuum leak & then backordered the replacement for 6 mos. Their quality control leaves alot to be desired, IMHO.
Old Sep 18, 2002 | 08:58 AM
tpi_roc's Avatar
The specific edelbrocks were the victor juniors..
For the price i was AMAZED at how horrible the intake runners were cast.. yea the workmanship was deffinatly lacking
Old Sep 18, 2002 | 08:10 PM
GMFREEK's Avatar
i have 86 iroc with the upgraded vortec heads lt4 hot cam scdp intake slp runners and it works very well with a six speed and 3.73 gears it did 13.2 in the 1/4 mile last week
Old Sep 18, 2002 | 08:42 PM
tpi_roc's Avatar
Nice run
ydnar417
Sep 23, 2015 05:57 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
