Brodix Track 1's.. which TPI intake
Old Sep 20, 2002 | 10:17 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
I saw a company a while back that made a tall port TPI base that will fit the Track 1's, does anybody know who it is?
Thanks,
Mark
Old Sep 21, 2002 | 08:54 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You might be talking about the SDPC vortec base, it is taller then the STD base to fit the 1/4 taller Vortec ports. You would have to modify the intake to work with the Track1 heads.
Old Sep 21, 2002 | 09:05 PM
Guest
Guest
Posts: n/a
I just talked to someone yesterday about this, he says the Edelbrock base works. The Accel base might work too.
Old Sep 24, 2002 | 07:10 AM
MJT's Avatar
MJT
Unless they've changed in the past 2 years, the Edelbrock base will not work. When we mated the Track 1's to the base, the ports on the heads were higher than the actual casting of the intake.
Old Sep 26, 2002 | 08:07 PM
89ProchargedROC's Avatar
LOL...i can attest to that
if you want to use some kind of TPI intake you are going to have to do a lot of welding and milling to make it fit
i'm running a victor junior converterd to EFI and there is just BARELY enough room to fit the port on my head
Old Sep 26, 2002 | 08:48 PM
TPIJeep's Avatar
I was reading that the TPiS intake has taller intake ports.. is this true?
Old Sep 26, 2002 | 08:53 PM
its just a ported version of the edelbrock base
LOL
Also...the track 1 heads aren't raised runner heads....they are just BIG ports
Old Sep 26, 2002 | 10:56 PM
Guest
Guest
Posts: n/a
I guess I shouldnt worry about getting a new base then if nothing TPI works.
Old Sep 27, 2002 | 12:43 AM
nope....not even the stealthram :-p without some welding
The LT1 intake probably not either......you could order the miniram to fit the big port though
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
