Pics of LT1 Intake with Aeroquip -12AN fittings/90 degree swivels
-12AN fittings are HUGE!!! I'll know this weekend if I have throttle body clearance (Edelbrock 52MM), but I'm thinking I probably won't. I'd like to find a way to run braided stainless lines. Has anyone else tried this?
http://www.s10wildside.com/pics/misc.htm
Also, see the pic that shows the -6AN fitting for the fuel pressure regulator. I had -6AN lines going to my TPI rails, so this is a perfect solution from TPIS (part number 500-608, and is $15.00). I'll tig weld a -6AN fitting on the fuel feed line.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
There's no way even the throttle cable bracket will attach with those elbows on there.
Yes, that's true...unless the side of it is cut. When I brought them home from Summit, I kinda figured it would be a tight (or impossible) fit. No biggie...I can return them.
I should be getting the '93 throttle cable bracket from my local GM dealer today. I don't suppose it has provisions for the cruise cable, does it? I don't remember your website mentioning the cruise control.
Well, maybe it does look like the bracket has holes for all three cables. My frustration is that my truck is in Erie, PA and I am in Cleveland, OH. I can only test fit and try stuff out in Erie. I just graduated college and took a job near Cleveland. I'm living in a high rise and don't have a garage.
I'm guessing the open end of that bracket is for the cruise control? Again, I can try out my cruise cable until I go to Erie this weekend.
I took a closer look at your 93 bracket....there's no way I can use those -12AN elbows without cutting the bracket and losing the ability to have a TV cable in there.
You never know until you try. I tried, and now I know.
