l98 cam
Old Sep 26, 2002 | 12:15 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
l98 cam
what is the rpm range on a stock l98 cam
Old Sep 26, 2002 | 02:44 PM
grumpyvette's Avatar
that would depend on factors like your engines displacement but if your talking about the stock L98 its about 1000rpm-5000rpm, above 5000rpm its low durration and lift restrict the engines breathing and power falls off quickly but since the stock TPI stopped flowing well at 4700rpm its effective torque range peaks near 2600-3200rpm its not a problem for the stock engines, this is the cam found in many L98 engines several cams were used the #14094728 was used in many early vettes (85-86)(its still available at some dealers but
http://www.gmpartsdirect.com/results.cfm
this cam (below)is used as a replacement stock cam with similar duration and lift
http://www.sdpc2000.com/cart.asp?act...d=993&pid=1569
Old Sep 26, 2002 | 03:42 PM
Car: 89 Camaro RS
Engine: 355 TBI
what about the lt1 cam
Old Sep 26, 2002 | 04:32 PM
what is it your really after? if your looking for a cam recomendation list every factor in your engine and car combo or call a cam manufacturer
I recommend
CRANE 386-258-6174 Tech Line
http://www.cranecams.com/CraneCams.htm
CROWER 619-422-1191
http://www.crower.com/
ERSON
http://www.mrgasket.com/pdf/Chevrolet.pdf
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
