please help me with heads
Old Oct 7, 2002 | 01:53 PM
SLOW91TA305's Avatar
I have a 89 IROC 350 with a blown head gasket. I already have the heads pulled off and I was going to send them to get a valve job. I've been planing to rebuild/build up my motor in a year.
I'm reconsidering getting better heads with some headers now, then upgrade the cam and intake next year.
So my question is which heads should I get for $1100. I also need to know which heads with work with my stock-everything else, plus be good when I swap the cam.
Old Oct 7, 2002 | 09:56 PM
CamaroX84's Avatar
Well it all depends on how much you plan on doing in the future. If you plan on doing some major cam/intake upgrades, wait and get some AFRs. The problem with getting them now is that it will run like crap, with everything else being stock, major mis-match in parts. If you want to get some good performance now, and have potential for a little more, I'd get some aluminum vette heads ported and throw those on there. Hope this helps.
Old Oct 8, 2002 | 09:49 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
I concur with the ported vette heads. I'm putting some on my car tonight as a matter of fact.
Hodge
Old Oct 9, 2002 | 12:51 PM
Warning...newbie question....
Where does one get ported aluminum vette heads?
Do I have to get used vette heads somewhere and have them ported?
thanks for the help
Old Oct 9, 2002 | 10:04 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
www.lingenfelter.com for ported vette heads (NOT CHEAP)
You could probably realize some performance gains for the same money by adding headers, cat back, air intake, lower intake, runners, etc & just clean up the stock heads.
Do a search-there are several options out there for $1100.
WARNING: modifying these cars is addicting. Reading this forum is hazzardous to your wallet.
Mine started as a 350 TPI automatic-so I know.
Old Oct 22, 2002 | 02:38 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
bbunting is right, these cars are addictive. I bought my car for 1800, and I've put about $2000 into it so far and I still have a long long way to go. I can't wait till I get out of college and can spend some real money on my car...
Old Oct 22, 2002 | 05:33 PM
PonchoDoc's Avatar
thanks for the help
I got some vette heads for sale in schaumburg, ad is in the classifieds. Already apart ready for port work. If you got the bucks get the AFR's though.
Old Oct 22, 2002 | 07:13 PM
Bort62's Avatar
I disagree, Some AFR 190's or 195's out of the box should work great on a Stock TPI. Of course they wont be fully utilized, But they should perform just fine.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
