Plenum Spacer
Old Oct 22, 2002 | 11:35 AM
JAKEDPLAYA's Avatar
Plenum Spacer
I HEARD SOMEONE METION A PLENUM SPACER. WHAT IS A PLENUM SPACER? DOES IT GO BEHIND THE THROTTLE BODY?
Old Oct 22, 2002 | 03:04 PM
5SIZ's Avatar
Car: 1987 IROC-Z
there is no such thing, and if there is such a thing as a plenum spacer it is totaly usless.
However there are Nitrouse plates that LOOK like a plenum spacer, except they give ya a little more kick if you know what I mean
Old Oct 22, 2002 | 03:50 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
What I think he's referring to is a throttle body spacer, which looks like a nitous plate. They have advantages on carbed and TBI applications but not on a TPI setup. It's pretty much useless.
Old Oct 22, 2002 | 04:03 PM
5SIZ's Avatar
Car: 1987 IROC-Z
plenum spacer, TB spacer.. same thing
Old Oct 22, 2002 | 06:16 PM
bigals87z28's Avatar
Car: Check The Sig
i didnt think there such a thing... then i saw one on Ebay... it has swirls to "improve flow" i gues it does what a air foil does... looks cheaper
Old Oct 22, 2002 | 06:23 PM
Car: Check The Sig
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1869469438 here is one....
Old Oct 22, 2002 | 06:26 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
No, any type of plenum spacer is a waste of time.a negligible increase in plenum volume is not going to affect performance at all.
As for the tornado TB spacer. Thats even worse. Swirl is also known as turbulence, exactly what we're trying to avoid in the incoming airstream by porting the plenum.
Old Oct 22, 2002 | 06:27 PM
5SIZ's Avatar
Car: 1987 IROC-Z
oh jebus......
I sure that does as much good as a TPS enhancer
Old Oct 22, 2002 | 10:32 PM
tpi_roc's Avatar
Old Oct 23, 2002 | 12:54 AM
Car: Check The Sig
i think that each TB plenum spacer should come with muffler bearings..... tb spacers are good for a TBI injected car...but no need for it on the TPI.... this is what i dont get... y isnt there any dumbass products out there for stangs? i never see any... and i always thought that the TPS enhancer was sketchy....
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
