Swapping heads
Old Nov 5, 2002 | 09:16 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Swapping heads
How difficult is it to swap the heads with the motor in the car? I have an 89 Iroc TPI with Edelbrock headers. Will I have to jack the motor up or is there enough room without doing so? Thanks.
Danny T
Old Nov 5, 2002 | 10:14 PM
Boxeat2469's Avatar
Its not too terrible. I have an 89 Formula 350 with Edelbrock headers. After the y-pipe is disconnected and the headers unbolted from the heads, the headers flop off to the side and leave enough room to get to all of the head bolts.
Old Nov 5, 2002 | 10:44 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
OK thanks. I forgot if my Y-pipe is welded or not. Guess I'll go check.
Danny T
Old Nov 5, 2002 | 11:41 PM
Boxeat2469's Avatar
Not the y-pipe to the exhaust system, but disconnect the y-pipe where it attaches to each header. This way when you unbolt the header from the head you have room to move it around.
Old Nov 6, 2002 | 08:17 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Yeah, doing the heads in the car isn't bad at all. I do recommend you take the hood off though. It just makes it easier to see and get to things without worrying about hitting your head on the hood.
Old Nov 6, 2002 | 01:08 PM
iroc22's Avatar
Remember you will have to drain the coolant outta the system. Save it all in a clean bucket so you can put it back in after.
Old Nov 6, 2002 | 07:44 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Those are some good tips, didn't think about the hood getting in the way. Thanks guys.
Danny T
Old Nov 6, 2002 | 11:01 PM
sbcfreak's Avatar
..knowledge learned from the bumps on other's heads! I like it!
Old Nov 6, 2002 | 11:06 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I can't believe nobody noticed that people are talking about two completly different things. He asked how hard it will be to swap HEADS with the engine in the car. He got a response about changing HEADERS with the engine in the car and replied to it as if it were what he asked. Others repliued to the actual question about HEADS. Logically, if you already have Edelbrock HEADERS, why would you want to swap out your HEADERS?
IDK, I have next to no experience with swapping either HEADERS or HEADS, but I thought I'd point that out.
Old Nov 6, 2002 | 11:28 PM
Boxeat2469's Avatar
L98IROCZ89
I wasn't telling him how to swap out headers. Last time I checked the headers were attached to the heads, and they have to be unbolted from the head in order to remove the head. I was just letting him know that he doesn't need to remove the headers completely to get to the head bolts.
Old Nov 6, 2002 | 11:38 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
OK, I will work on my reading skills!
Studying international econ all night did that to me...
Carry on.
Old Nov 7, 2002 | 12:17 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Exactly. I noted that I have headers because I figured it would make a difference as to how difficult it would be to swap HEADS while in the car compared to if I still had the stock exhaust manifolds.
Danny T
Old Nov 7, 2002 | 02:29 AM
Morley's Avatar
If you are going to be putting iron heads back on the engine be VERY careful when setting them in place. They weigh a ton ( 50 lbs each) and you'll be bending/leaning way over setting them in place, one little slip can ruin the head gasket.
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
