LT4 HOT cam and timing chain set
Old Nov 16, 2002 | 08:37 PM
S10Wildside's Avatar
I'm about one week away from getting my motor reworked. I'm installing the LT4 HOT cam kit and need to know what timing chain set I should be looking for.
What chain set (I guess I need the gears too) is compatable with my motor...it's a L98?
What are the LT4 HOT cam people using?
Old Nov 16, 2002 | 09:19 PM
kevinc's Avatar
Car: 1982 Z28
On my L98 I used a Cloyes 3-way timing set which included both gears and a double-row roller chain. $80 or so from Summit, make sure you specify you want the one for SB Chevy w/ factory roller cam...the cam gear bolt pattern is different than pre-roller cams.
You reuse the thrust plate which bolts to the front of the block behind the cam gear, no mods needed w/ the HOT cam.
Make sure and have the machinist install new cam bearings, good practice.
Old Nov 17, 2002 | 05:08 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I used the GMPP single roller HD timing set (p/n 12371043). Was about $40 from the dealer my price. It may be a single roller set, but the thing is about the size of most of the doubles I have seen. Oh, no problems at all with it on my engine . It is for factory roller engines.
Old Nov 19, 2002 | 07:04 PM
383 rocket bird's Avatar
I used the GMPP timing chain set as well and as stated as before it seems very heavy duty and a good piece.
Old Nov 20, 2002 | 04:32 AM
Thanks for the replies...I went with a Cloyes timing set from Summit. It was much less $$$ than GMPP
Old Nov 20, 2002 | 01:15 PM
Yeah dealer stuff is quality but I get a discount like the other guy stated above said too. Without a discount it can sometimes be probibitively expensive and better to just go aftermarket and get a quality product like you did there. Good luck
Old Nov 22, 2002 | 05:24 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Make sure you get a timing chain/gears for an LT1/LT4 type cam.
Because the L98 is different.
Old Nov 23, 2002 | 06:06 AM
kevinc's Avatar
Car: 1982 Z28
I was worried that might be the case when I built my engine in 1998, measured my L98 cam and the LT4-HOT cam and the bolt patterns are identical. The machined step up front for the thrust plate is identical.
Go read a book or something instead of giving out bad advice.
Old Nov 23, 2002 | 11:21 AM
Right, the set I bought (Cloyes Roller Setup) fits my LT4 HOT cam with no trouble.
Old Nov 23, 2002 | 02:10 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
When I was building my motor , I ordered a chain set, from Jegs, for an L98 as well. It was a wrong one. Perhaps they sent me a wrong set, I don't know. I told the guy I had an LT4 cam and I got the right set afterwards. I did not compare the 2 cams; regardless my advice is still valid either way you look at it.
So go ahead and stick a book up your ***, punk. Preferably a hard cover.
Old Nov 23, 2002 | 02:18 PM
Hey man, I didn't mean anything by what I said. I appreciate all the info I can get. Your post made me question the shop who's doing some machine work to my motor (about proper fit to my LT4 HOT cam). It looks like the timing kit I bought will work, but it's something for me to keep in mind in the future. Thanks for the post.
Old Nov 23, 2002 | 03:22 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
My comment wasn't geared toward you. It was the other guy who told me to read a book. I was just speaking from my own experience.
Old Nov 23, 2002 | 03:56 PM
kevinc's Avatar
Car: 1982 Z28
Or lack thereof.
It sounds like Jegs sent you a pre-'87 timing set designed for the older hydraulic flat-tappet cam. The cam gear bolt pattern is definitely different than the newer hydraulic roller cam design.
No need to thank me, dude. People like me are here to prevent people like you from messing up people like the guy who asked.
Old Nov 25, 2002 | 12:14 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Or lack thereof.
So you are saying the 350 motors in use prior to '87 are not L98's?
Old Nov 25, 2002 | 01:08 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
One thing to watch is the dowel pin on the Hot Cam, IIRC it needs to be pushed in a bit to keep it from rubbing on the timing cover.
Yes pre 87 350 TPI are L98, however pre 87 are non roller blocks, with 2 piece rear main seals.
Old Nov 25, 2002 | 01:18 PM
DURTYBIRD's Avatar
You can also cut it to the appropriate length.
Exactly. So when kevinc posted:
He was only partially right, therefore also spreading his own brand of 'misinformation'. Maybe he should go read a book? LOL!
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
MY87LT
Aug 17, 2015 08:43 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
