MSD ignition
Old Nov 17, 2002 | 02:32 AM
HI92Z28's Avatar
Engine: stock 350 TPI
Transmission: rebuilt stock tranny, b&m shiftkit
MSD ignition
Planning on a MSD ignition 6AL. Where do you guys put that dam big ignition box. There seems to no room under the engine compartment.
Any noticabe improvements with the 6AL? Would it help gas mileage?
Old Nov 17, 2002 | 02:51 PM
MdFormula350's Avatar
msd says that fuel mileage will increase. some mount the box around the drivers side firewall...
https://www.thirdgen.org/techbb2/sho...hlight=msd+box
Old Nov 17, 2002 | 03:25 PM
HI92Z28's Avatar
Thanks for the link!
Should I go with the A or the AL. Is the only difference is the two step rev limiter?
Old Dec 21, 2002 | 12:39 AM
CrashedMatrix's Avatar
the 6al has the single high rev limiter and the 6a doesnt have a rev limiter at all.
Old Dec 21, 2002 | 12:42 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
6AL has an adjustable rev limiter.
Old Dec 21, 2002 | 12:59 AM
fattie92's Avatar
i had my box right behind my headlights cause it is supposed to be the coolest spot in the engine bay......but man that thing gets HOT!!! so i mounted it on the inside of my car, on the drivers kickpanel. as long s you dont have a stick, its fine. i think it looks good there, great locatin to run wires, and most importantly it doesnt get hot.
Old Dec 21, 2002 | 08:42 AM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Does your car have A/c? I have mine mounted on the passanger firewall.
Old Dec 21, 2002 | 09:56 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I just ordered an MSD-6A for my 91 Z28....getting it for christmas....but...I'll probably have the saae problem mounting it somewhere.......anbody have any pics of their ignition boxes mounted??
Old Dec 21, 2002 | 11:49 AM
fattie92's Avatar
if you want them to last a long time, you need to put them inside the car.
Old Dec 22, 2002 | 07:39 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Brain dead question!!!
How do u mount up a MSD ingnition system in your car? where does it plug into??
Old Dec 22, 2002 | 07:46 PM
fattie92's Avatar
go to www.MSDignition.com
Old Dec 22, 2002 | 07:50 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
thanks for the link but my comp is to slow in downloading that. Stupid 28.8 modoms!!
Old Dec 22, 2002 | 07:56 PM
fattie92's Avatar
well its pretty simple........... there are wires that go to your battery... then your tach, ignition and distributor. the hardest part of the install is mounting the box and then hiding all the wires and making it all look good.
Old Dec 22, 2002 | 08:33 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I put a Digital 6+ on my vette. If you want to make the MSD install easy buy the $15 wiring harness correct for your application! MSD should have them listed on their site somewhere.
Old Dec 22, 2002 | 08:36 PM
355formulatpi's Avatar
I got the crane fireball, it for about the same price, it has a rev limiter, and a lot smaller!! Ther is a pic of it, and my supercoil by the a/c dryer in my signature! Later!!!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
