TPI Computer Question
Old Nov 25, 2002 | 02:12 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I am having a problem with reading my codes. I am getting a "veh. not responding" the problem is that its running fine but it did have a incident where it backfired and bucked a few times. I thought it was in limp home mode but it Starts good......runs good.....has power it always did. Could the computer still be bad and the rest go so well.
Thanks for the input
Brian Felts
Old Nov 25, 2002 | 06:50 PM
Bort62's Avatar
What are you trying to scan codes with ?
Old Nov 25, 2002 | 06:53 PM
Auto X Ray..........the scanner is working. I used it on my Z71 right after that. I know the ALDL is working because a couple of weeks ago I scanned a code on it then.
Brian
Old Nov 26, 2002 | 09:46 AM
Desert86Roc's Avatar
That error occurs when your cables are not plugged all the way in, or it is not making good contact at the ALDL. Check your cables again. The Autoxray cable has a habit of not being plugged all the way into the scanner.
Old Nov 26, 2002 | 09:50 AM
Jza's Avatar
Jza
Occasionally I'll forget to turn the key on...
Old Nov 26, 2002 | 11:40 AM
S10Wildside's Avatar
My Auto XRay has the same problem. Sometimes it says "Vehicle Not Responding", other times it works.
I haven't found the problem...but maybe it is a loose cable like these guys are saying.
Old Nov 26, 2002 | 11:44 AM
Hey I will go out and try it one more time and see what happens. I have a hard time believing the computer in bad since it seems to run so well.
THanks
Brian
Old Nov 26, 2002 | 01:48 PM
Jza's Avatar
Jza
Have you upgraded your AutoXRay to the latest version of the software? I believe there were some issues fixed in the latest release. If you want them, I'll get you the pinouts to hook your AutoXRay to an RS232 port so you can make your own cable and upgrade it yourself (or you could just buy their cable). I just don't know if they're straight cables or if there's any sort of an interface inside it. If it's the former you'll be all set.
Old Nov 26, 2002 | 01:59 PM
JZA...I don't know about the upgrades you are speaking of but I just bought the pro-pack 2 weeks ago. Do you think I am missing something?
Brian
Old Nov 26, 2002 | 02:03 PM
Jza's Avatar
Jza
I got the PC-Link software with my AutoXRay and it has an option to "upgrade" your scanner to the latest version. If you go into the CONFIG button on the XRay there's like a "system info" or something like that that tells you the version that you're running and mine was behind. So I click the button, it goes on the internet, downloads the upgrade, then upgrades my scanner via the PCLink cable. Did the Pro-Pack come with PCLink?
Old Nov 26, 2002 | 02:05 PM
Jza's Avatar
Jza
That wasn't too clear... I mean I click the upgrade button on the computer to upgrade the scanner...
Old Nov 26, 2002 | 02:21 PM
Hey guys I got it working.....I think Desert86Roc was right the cable was just not working. All is good........also thanks for the upgrade info I will have to get the pc link going for mine.
Brian
Old Nov 26, 2002 | 03:01 PM
Jza's Avatar
Jza
Old Dec 19, 2010 | 11:22 AM
Guest
Guest
Posts: n/a
Re: TPI Computer Question
Hi can I ask you for the pinouts to hook your AutoXRay to an RS232 port
thanks
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
