mother@#(&^&^ not again
Old Dec 15, 2002 | 12:00 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i have an 89 gta 350 tpi and i was driving and then it just started kinda like slowing down i give it more gas and it doesnt accelerate so i give it more then it just takes off loud and fast.service light turns on so i pull over and put it in park and the light goes away and doesnt come back. the next day i check all the sensors and same prob but now it over heats.i figure blown head gaskets. i spend 3-5 weeks(i did blow head gaskets) getting heads rebuilt (had a bent valve and weak springs) i also put new pushrods cuz old ones were bent bad and a new timing chain. i inspected the lifters no damage put every thing back together but put a adj. fuel reg and port plenum. i go to take it out and the same prob again what the hell can be wrong?i spent lots of money and time for nothing what could it be?
Old Dec 15, 2002 | 04:32 PM
demon138's Avatar
please i need input
Old Dec 15, 2002 | 04:40 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Did you pull the trouble code?
Old Dec 15, 2002 | 04:58 PM
demon138's Avatar
no but i should have also i noticed that my ehaust sounds very very bass like and it was never like that before
Old Dec 15, 2002 | 05:01 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I understand your frusturation, and I cannot begin to help as my experience falls far short of your predicament.
However I'd like to be a consoling voice and tell you you did not spend money for nothing...
New pushrods, you found problems with your heads, and you ported the plenum and threw in an AFPR - this is all good stuff!
The best of luck isolating the trouble beast.
Old Dec 15, 2002 | 07:43 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
The computer will still store the code(s) even if the SES light goes out unless you disconnect the battery
Old Dec 15, 2002 | 08:09 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Were the heads straight and milled before you put them back on?
Did you find out what caused the first set of gaskets to go? Any rings around the cylinders broken? How many pushrods were bent and how bad? Is there water in the oil?
Old Dec 16, 2002 | 10:57 AM
demon138's Avatar
i had the heads checked for straightness and for cracks. had bent pushrods on the same side as blown gasket bent pretty bad no water in oil but when i checked for water it was almost gone no foam in it.
Old Dec 16, 2002 | 12:39 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
What is your engine temp? You said you changed the timing chain, did you re-install it with the dot lined up, and when you took the old one off, was it out of alignment, like if it had moved a tooth?
What is your inital timing at?
Old Dec 16, 2002 | 12:47 PM
Morley's Avatar
Never, ever use old valve train components with new ones. New lifters cost so little it isn't even funny, you should have replaced them.
Old Dec 16, 2002 | 01:40 PM
Brian'sIROC's Avatar
his car is an 89, so I assume they are roller lifters, which are OK to reuse if they are inspected first. If they are flat tappet lifters, then they should never be reused.
Old Dec 19, 2002 | 10:41 AM
demon138's Avatar
they are roller it was the timing. it was retarded way too far to operate properly. prob solved but no i noticed it leaks from the front main seal how can i fix it the easiest way?
Old Dec 19, 2002 | 02:26 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
leaking from at the balancer shaft, or from in between the timing cover and oil pan ?
sounds like fuel system problem of some kind
Old Dec 19, 2002 | 03:52 PM
demon138's Avatar
only prob i have now is the leak its from oil pan to timing cover
Old Dec 20, 2002 | 01:01 PM
Steve89GTA's Avatar
Dude, that definitely sounds like an ignition problem to me. Check/replace your ignition module and ignition coil. Make sure all plugs are firing!
Old Dec 20, 2002 | 07:05 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Clogged cat? Whats yur exhaust setup?
Old Dec 21, 2002 | 03:17 PM
demon138's Avatar
it was a timing prob i fixed it i have no cat now it just leaks
Old Dec 22, 2002 | 01:51 AM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Had a similar problem. Turned out it was a fuse not activating my electric fan, causing massive overheating while idling/traffic/drive thru...Somethin minor like that.
Old Dec 22, 2002 | 10:59 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Never mind, I see you've fixed the problem.
92GTA
Apr 9, 2016 07:39 AM
TonyC
Feb 24, 2004 05:46 PM
88305tpiT/A
Jun 12, 2001 09:09 PM
