Stupid question about gaskets....
Old Dec 16, 2002 | 12:06 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I'm replacing my intake manifold gasket for the first time. Felpro recommends you put a small amount of RTV on back of gasket and set the manifold on to heads and tighten slightly. It says wait X amount of time then remove to make sure the gasket didn't shift and to cut away excess material covering ports. My dumb question is do you place the gaskets on the manifold or the heads?
I'm ditching the cork end gaskets and bought some ultra black RTV silicone based on what others have told me. Any other tips?
Old Dec 16, 2002 | 08:37 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Are you sure that's what the directions said? I've never done it that way. Run some rtv around the water jackets and you should be OK.
Old Dec 16, 2002 | 09:36 AM
Ragtop89's Avatar
What's RTV??
Old Dec 18, 2002 | 02:34 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I have Fel-Pro 1204 gaskets on my vette right now. I dab a small maybe 1/2 dime size amount at the front and back of the gasket and press it onto the head and hold it in place for 30 seconds. This will typically keep it in place long enough to do the other one and set the manifold on it.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
