which intake would you rather have?
Old Dec 30, 2002 | 07:58 PM
Kandied91z's Avatar
super ram or mini ram?
Old Dec 30, 2002 | 08:11 PM
DABE's Avatar
neither....carb!
T ram would be swweeeetttt
Old Dec 30, 2002 | 08:44 PM
Kandied91z's Avatar
Old Dec 30, 2002 | 08:46 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Super Ram. And that's not just cuz of smog reasons.
Old Dec 30, 2002 | 09:26 PM
BRIrocZ's Avatar
Car: 97 Z28
Transmission: A4
For my intents and goals definitely the SuperRam. If I were building a 383 I'd lean more toward the Miniram though.
Old Dec 30, 2002 | 09:31 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Superram. Be legal. Be super. =D
Old Dec 30, 2002 | 10:27 PM
Steve10's Avatar
Are you talking on stock heads and cam? The whole combo has to be right, including the intake. Heads, cam, stall and gears are a must to get the most from either of these intakes. Personally, I say go ahead and get the Miniram or HSR, or LT1 like I did, and it will be the last intake you buy no matter how extreme you mod the car. What's your goal for the car?
Old Dec 30, 2002 | 11:54 PM
Kandied91z's Avatar
just trying to figure out the right combo and stay around 7,000 tops on the engine alone.
Old Dec 30, 2002 | 11:58 PM
MdFormula350's Avatar
i was looking into the super ram myself.
Old Dec 31, 2002 | 12:36 AM
BORLAZ06's Avatar
kill the wildlife..StealthRam :lala:
Old Dec 31, 2002 | 11:15 AM
Jza's Avatar
Jza
Miniram.
But...
Need I remind anyone of a certain red 89 IROC with a Vortech-fed 420 with a Superram? Wipes up drool puddle.
Old Dec 31, 2002 | 11:32 AM
Jza's Avatar
Jza
There it is..
Old Dec 31, 2002 | 01:16 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Tom Pansey's?!? (sp) Isn't that supossed to be like the "best" thirdgen ever? Well, in the public's eye/magazine's anyway. Is it still in that condition? That car has looked like that even before i had my car like 5 yrs ago. Pretty sweet, except for the paint, IMO.
Old Dec 31, 2002 | 01:21 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I would prefer the Super Ram because you loose a whole lot of torque with the mini and the smallest engine you could use a mini with would be a 383, if that.
Old Dec 31, 2002 | 01:39 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Everyone has their own opinions obviously! You just need to pick which will suit your needs best. For a little more bottom end go with the SR, for top end MR, for a compromise of both HSR. If you do it by price, first you would pick the HSR, SR, and then the MR.
Old Dec 31, 2002 | 02:44 PM
Guest
Guest
Posts: n/a
Of those two? Miniram.
Old Dec 31, 2002 | 03:28 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Between those two, superram.
Old Dec 31, 2002 | 05:27 PM
Kandied91z's Avatar
well super ram is out of the question, not only is it a pain in the butt to work with but there are plenty of places for vaccum leak problems. to many parts here and there.
thanks for all the replies guys!
Old Dec 31, 2002 | 05:30 PM
scorp508's Avatar
Car: Corvettes
Nah, its simple to work with once you've done it a couple of times. It gets a bad reputation for nothing.
Old Dec 31, 2002 | 06:15 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Miniram.
Old Dec 31, 2002 | 07:39 PM
ImportsRsloths's Avatar
The super ram gets a bad reputation for a good reason.......... its a multi piece intake manifold that requires many gaskets and of course runs a lot better chance of getting vacuum leaks......
The mini ram or LT1 manifold is a single piece manifold that is easy to work on, easy access to fuel system etc....... id say the miniram for sure, but you need a bigger engine for it..... if your going 350, id go LT1 intake.......
Old Dec 31, 2002 | 07:40 PM
scorp508's Avatar
Car: Corvettes
....hesitations, leaned out cylinders.....
Old Dec 31, 2002 | 08:24 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
LOL, why did you ask the question then if you already had your mind made up?
Old Dec 31, 2002 | 11:13 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Despite the possibilty of vaccum leaks, I would STILL go with the superram. Maintain low end torque, whilst revving up to 6,000rpm... AND SMOG LEGAL! What the hell more could one ask for? All the other intakes are great, but only the Superram offers egr provisions. So what if it's a PITA to install? Lots of mods are a pain in the ***, but we do them anyway don't we?
final note on my opinion: Vaccum leaks are not a lethal threat anyhow. A heavy duty adhesive smeared over any seams b/w intake sections will ensure that a bad gasket wont throw a cog in your operation.
Old Jan 1, 2003 | 05:11 PM
Matt87GTA's Avatar
Hesitations? Heard of tuning? ...... Leaned out cylinders.... hmmm... maybe. Enough to worry about? Nahhhh...
Old Jan 1, 2003 | 05:14 PM
scorp508's Avatar
Car: Corvettes
Oh hell yeah, just seems that too many people experience it. I'm thinking of cutting a hole in my hood to try out the stealthram though.
Old Jan 1, 2003 | 08:32 PM
Ragtop89's Avatar
I'm very with happy with the way my SuperRam performs for me.
I don't have any dyno #s or track times for you but my butt-dyno says there is a lot more umph there than there was before.
I've spun the tires thru 3 gears.
When Romp on it I can FEEL the frame tweak.
I need some SFCs . . .
And I've ran my 355 up over 6500 rpms with my SR.
I couldn't do that with my stock TPI.
Old Jan 1, 2003 | 09:02 PM
rezinn's Avatar
double post
Old Jan 1, 2003 | 09:03 PM
rezinn's Avatar
Miniram, no doubt about it. If I didn't have smog...
Old Jan 1, 2003 | 10:34 PM
Steve10's Avatar
No way! I'm running a LT1 intake, which is the same as the Miniram, on a ZZ4 and it makes tons of torque. If you run the right gears and get it tuned decent, you will be like me...concentrating on how to hook up all this torque. I was running a full Accel LTR setup on this motor a few months ago, so I know what tons of torque feels like. When I switched intakes, at first I felt a little loss in torque. Then I went from 3.27 to 3.73's, and burned a few chips, now it feels like even more torque, especially with the 3200 Vigilante. Again, it's all about the combo. I gained 35-40hp from the intake switch, but keep in mind, I already had the cam and ported heads, so it was just waiting to breathe and rev.
Kandied 91Z, if you're going to build a combo to spin up to 7000 rpm, definately go with the Miniram or LT1.
Old Jan 1, 2003 | 10:37 PM
scorp508's Avatar
Car: Corvettes
Originally posted by Steve10
Then I went from 3.27 to 3.73's.....
That right there completely nullifies that post. Had you tuned everything with the same gears a comparison would be fair. You have now completely changed the torque multiplication for your car making it all different.
Old Jan 2, 2003 | 01:42 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I'm in the same boat. I really want to try the HSR out and see how it compares to my SR, direct comparison with no other changes. If I can maintain or improve from where I'm at and lose all the bolts and complexity of the SR at the same time, I'd be happy.
Should be interesting!
Old Jan 2, 2003 | 04:34 AM
Matt87GTA's Avatar
Then 'too many people' don't know how to tune . The majority of the people that I see having the tip-in lean miss problems (hesitation) are either people with off the shelf PROMs or DIY PROM tuners that alleviate the problem shortly after posting in the DIY PROM forum . The Miniram is the $hit..... Just no way around that fact. Course..... it is quite a bit more $$$$$ than the other intake options out there...... Oh well .
Old Jan 2, 2003 | 09:44 PM
Steve10's Avatar
If you would please read what I was responding to. The point I was making is that many people are running the short runner intake design on a 350. You don't have to have "minimum 383". I was pointing out how well the LT1 works with my 350. If your going to gain an extra useable ~1200rpm up top anybody knows you gotta change gearing. If someone is looking at either of these intakes, there probably looking for 12's, and that means there probably going to be doing a gear change to get the most out of either.
Old Jan 2, 2003 | 11:29 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Speaking of times, Steve10, do you have any to give? Have you been to a track yet with the current set up? Later
Old Jan 3, 2003 | 12:21 PM
grumpyvette's Avatar
IVE POSTED THIS BEFORE< THE STEATH RAM IS THE BEST BY FAR AT MATCHING THE ENGINES PEAK and POTENTIAL HP CURVE IF YOUR GOING TO MODIFY THE ENGINE FOR MOR HP
Ive run all 4 common intakes
ported tpi
super ram
mini ram
stealth ram
the ported tpi gained me about 20hp over the stock TPI.(power range, 1500-4500rpm
super ram gained me about 45hp over the stock TPI(power range 2000-5500rpm)
the mini ram ram gained me about 55hp over the stock TPI but lost torque below 5000rpm(power range about 5500-7500rpm)
the stealth ram gained me about 68 average hp and close to 90hp at peak but lost torque below 4000rpm compared to the stock TPI intake (power range about 4000-6800rpm)
now keep in mind Ive got a full roller 383 11:1cpr with ported trickflow heads and full length headers, the stock TPI totally strangles that engines airflow above 4500rpm, so any intake system that flows more air lets the engine breath and produce better hp, the steath ram and the other intakes require a cam and headers to effectively use the better airflow
Old Jan 3, 2003 | 11:11 PM
Steve10's Avatar
This was my first and only time to take the car to the track about a month ago. I've added the 3200 Vigilante converter since then. I had a crappy 12" 2500 stall converter before. As you can see by the 60' times I couldn't get any traction, even on drag radials. There was water all the way up to the line from the import guys. I ran 8 times and averaged 12.9's @108. I'm going to a known good track in Sequin next time and see what it will do with the new Vigilante and some traction.
Attached Thumbnails which intake would you rather have?-timeslip-11_30_02.jpg
Old Jan 4, 2003 | 09:25 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Not bad, but i am sure you have a lot more left in it! Or comapred to other set ups you should atleast. Good luck with the traction issues. And thanks for posting that-Bryan
Old Jan 5, 2003 | 05:27 PM
85l98's Avatar
i have the super ram
http://hometown.aol.com/corkvette1/myhomepage/auto.html
Old Jan 5, 2003 | 07:04 PM
Car: Damn
Engine: This
I'm guessing RCR? let me know when you go, that's where I race. You WILL hook out there!
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
