For Those with SLP headers
Old Jan 23, 2003 | 05:14 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
im going to look at a used set this weekend, how do i tell the difference, how will i know if they are SLP or not, is it stamped? they are 1 5/8 with AIR
-mark
Old Jan 23, 2003 | 05:38 PM
Morley's Avatar
Re: For Those with SLP headers
-mark
They have a little tag welded to them above the collector, it says SLP.
Since they are really the only stainless headers of that type it'll be easy to tell.
Old Jan 23, 2003 | 06:55 PM
breathment's Avatar
Re: Re: For Those with SLP headers
hmm i don't remember mine having this tag. maybe i just never noticed it.
but SLP headers with AIR have the air tub sticking straight up, and they have seperate flanges for the tubes. one for the left tube, middle two tubes, and right tube. so thats three flanges. and they are THICK flanges too. almost all other headers have a single flange.
Old Jan 23, 2003 | 07:32 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Heres a pic of my 1 3/4 SLPs.
Old Jan 23, 2003 | 08:02 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
note the lack of rust(thick flaky), but not bright and shinny like a coating. That's stainless steel, I don't think anyone else makes SS headers so.
Old Jan 23, 2003 | 08:57 PM
Morley's Avatar
And the SLP tag tack welded to the tube, sorry I thought mine was welded more towards the collector end.
Old Jan 23, 2003 | 09:37 PM
'89 IROC Vert's Avatar
And heeeeeere'sssss mine...
Old Jan 23, 2003 | 09:54 PM
Engine: LS7
Is that a TBI car " '89 IROC Vert" you rich Bast*rd. J/K. Vert.=$$$
I'll show you the light soon to the low 14's(if you're not already there).
Old Jan 23, 2003 | 10:22 PM
87 B4Z's Avatar
here they are off the car
<img src=http://groups.msn.com/_Secure/0SgDbAhgW3DMnALb6ZfHZ66E2bqRfO95M5jmhaSdAzfffbsZhVvyh1CFGHS8KuIStuvuD1E6JE91!WjRDAJam9qvcJAJFXUKauQr6nH5pgFvVgCGXhqixqw/Image0100.jpg>
Old Jan 23, 2003 | 11:42 PM
breathment's Avatar
hmm to the ceramic coated headers not have the SLP badge? cause i know mine don't have it.
Old Jan 24, 2003 | 07:20 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The older SLP headers did NOT have a tag on them. The design is exactly the same ... they just didn't have a tag. I'm pretty sure that there are more SLP headers out there without the tag than with the tag.
I had SLP 1-5/8" that did not have the tag. Now Ed Maher has them
Tim
Old Jan 24, 2003 | 11:39 AM
Jza's Avatar
Jza
Here's a good view/shot of mine.
<img src="http://home.centurytel.net/jza/89RS/images/89RS%20-%20Header%20Install%20-%20Jet-Hot%20Coating.jpg">
The big tell-tale is going to be the thick seperate flanges with the spacer tubes welded in place.
Old Jan 24, 2003 | 01:38 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
From what I have seen it looks like SLP started doing it about 3 years ago. I know my friend Synapsis has the tag but I don't and mine are about 4 years old.
Old Jan 24, 2003 | 02:22 PM
Z28DJP1987's Avatar
Test them with a magnet, it will not stick to Stainless Steel. One sure way to check if they are SLP's.
Old Jan 24, 2003 | 05:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I don't know about the magnet thing being they still do have some iron in them, they are a lower grade of stainless. mine are 1 3/4" bought them in 96 and they have no badge.
Old Jan 25, 2003 | 08:23 AM
STIFFLER's Avatar
Tim
My friend has a set aswell that does't have the tag on them.. basically look at the flang that bolts to the head.. SLP's are quite thick up there.. compared to cheaper ones.. or they say take an AWL and try and scratch the inside of the collector.. you might put soem kind of scratch on it but it will wipe off.. Stainless metal is a little harder to scratch then plain steel ones..
Old Jan 25, 2003 | 09:02 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It's 409 stainless which a magnet will stick to.
Old Jan 26, 2003 | 04:37 PM
86irocL98's Avatar
Car: 91 TA vert
Engine: 355
ok...thanks all...
Old Jan 26, 2003 | 09:13 PM
MdFormula350's Avatar
tight fit on those drive side headers!! but looks like they made it in!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
