Code 33 Fixed?!?! Milage/performance better !?!?
Old Jan 25, 2003 | 06:02 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Fixed my code 33 today, The wire leading to terminal "E" on the MAF sensor was cut by my alternator pulley. Im not sure of that is one of the S.E.S light triggers that puts it into Sh** mode...
Should I expect better milage, or performance now that it is fixed?
Could that have been the cause of my intermittent non starting problem explained here:
https://www.thirdgen.org/techbb2/sho...ight=emergency
Old Jan 25, 2003 | 10:04 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
Whats a code 33?
Old Jan 25, 2003 | 11:25 PM
86FyrBrd's Avatar
Code put out by the computer signalling high (or low, but I think 33 is high) MAF reading.
Old Jan 26, 2003 | 10:37 AM
86FyrBrd's Avatar
TTT
Old Jan 26, 2003 | 04:33 PM
86FyrBrd's Avatar
Gonna tell me no one here knows if that would have caused starting problems and be fixed now?
Old Jan 26, 2003 | 07:31 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Don't know about the hard starting problem, but having the code fixed will give you back some performance and probably gas mileage.
Old Jan 28, 2003 | 10:28 PM
88IROC_CVTFAN's Avatar
Tripping code 33 (MAF high) will put the system in "limp home" mode. In other words the engine is run off of a set of default settings for spark, fuel, etc.. Many TPI folks (with MAF systems)have encountered this at some point.
Like the previous response, can't guarantee this would cause hard starting since the motor is on the defaults when it's cold, ie, running open loop.
I know in my experience the motor runs rougher and the gas mileage suffers.
Old Jan 28, 2003 | 11:57 PM
bigals87z28's Avatar
Car: Check The Sig
i got a code 34, the other one... im replacing my MAF after i checked all my relays
Old Jan 29, 2003 | 06:19 AM
86FyrBrd's Avatar
Dont overlook the wiring itself.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
