new rocker arms with stock 305 cam??
Old Feb 6, 2003 | 01:12 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i have a 89 iroc 305tpi----
i don't want to replace the car at this piont-
-has anybody ever done this and if so with what rockers
-what are the stock ratio for my current rocker arms.
i'm looking at 1.52 - 3/8" Comp Cams 87-Up SBC Magnum Roller Tip Rocker Arms
the are like 200..
what otrher parts will i need when replaciong these
Old Feb 6, 2003 | 01:23 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
Those rockers are an excellent choice. I plan on adding a set to go with my Crane Cam, but I suggest you get a better than stock cam to go with them to make a good noticable differance.
I am using the same COmp Cams magnums 1.52 ratio on my Z24
After a year they hold strong and car produces 225fwhp over the 140hp stock
Hopefully I can see some big improvements in my 305 this summer. I am not adding to much, cuase I have a 400 sb I'm building but the CAM and Rockers and some porting and head work ougth to be nice for the next year.
Old Feb 6, 2003 | 06:25 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
What other mods to you have to your front driver to get 225 fwhp out of it?
Old Feb 6, 2003 | 08:56 PM
un4givin89's Avatar
9.3:1 compression from stock 8.1
bored .030
JE .75MM Hypertechtic Pistons
Crane Cams Chrome Moly Pushrods
Manley Forged Aluminum Rods
1.52 Ratio Rocker Arms
Crane Cams PowerMax
Adv. Duration: 264º/274º
Gross Lift: .423''/.423''
Stage II Jet Chip
Aluminum Heads 3-angle valve job
Hypertech 160 degree thermostat
Perma-Cool Engine Oil Cooler
MSD 8.8mm Sprial Core Wires
Champion Racing Spark Plugs
Accel DIS SuperCoil Packs
FDP 62mm Throttle Body
Ported Intake & Plenum
Shifter Improver Kit
305 19lb injectors vs stock 15lb
Hi Flow Intank fuel pump
K&N Air Filter
Cold Air Intake
150hp EFI NOS Kit
Magna Flow 2 1/2 exhuast with 3in outs
Exhuast, off road pipe, 2 1/2inch pipe
Thats about it.
Old Feb 6, 2003 | 08:57 PM
un4givin89's Avatar
Can't wait till I am done building my 427 for the IROC
Old Feb 7, 2003 | 12:56 AM
rezinn's Avatar
You've got a fwd iroc?
Old Feb 7, 2003 | 01:36 AM
AlexJH's Avatar
Engine: 5.7L V8
LOL. No, those mods are on his Z24!
Old Feb 7, 2003 | 01:41 AM
Engine: peanut LB9
no thatz his Z24 which is front wheel drive
and i'm looking at the gm ram jet cam, i don't ave alot of cash to spend, plus the am i only 135. i'm also looking at the LT4 in a future rebiuld
Old Feb 7, 2003 | 06:31 AM
The LT4 cam isn't all its cracked up to be, its over hyped on this board. Really the duration and lift is no greater than some Comp, Crane or Lunati Cams you can order.
You've got a 305 with breathing problems so don't go to radical.
Something that gives you good torque and horsepower low to mid would be good for a 305.
With those 1.6 ratio rockers a ported plenum, high flow runners, and good free flowing exhuast, and if you have the money or time, porting your heads and vavle job. You chould see a good increase.
I think I saw you have a 5-speed which puts you in the higher HP range for the 305 to begin with. So taking it up some shouldn't be all that difficult.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reborn756
Sep 4, 2015 03:42 AM
happyhapka
Aug 15, 2015 04:42 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
