ZZ4 cam in stock L98
Old Feb 13, 2003 | 09:55 PM
jaminJimB4C's Avatar
Car: 1991 RS B4C
Engine: Stock 350
I just picked up A zz4 cam and lifters for $75 and plan on putting them in my 1991 RS B4C with a 350. The motor is completely stock (for now). Will I need to have a chip burned or need screw in studs for this?
Old Feb 13, 2003 | 10:32 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
You will need a lot of things, like a set of new springs, a modified PROM, probably hardened pushrods, and you will need to do other work to your heads like machining the valve guides and so fourth to accept that kind of lift. I don't know about the screw-in studs however. But it doesn't matter anyway, that zz4 cam is way too much for your stock heads/induction combo. If anything, it'll make you slower, because that cam will trade off all the lowend torque that tpi and those heads are designed for, for a top-end that those same pieces can't support. I'd wouldn't advise putting it in without giviing your heads and induction some attention.
Old Feb 13, 2003 | 11:27 PM
REDZ28's Avatar
I totally disagree with REDFIREBIRD. I put the zz4 cam in my 91 z28 and it picked up 2 tenths and 1.5 mph in the 1/4. I didnt even have the heads machined for clearance. Also that was with stock exhaust maifolds.It ran even better with the headers installed.I ran a best of 13.11 with that camshaft and various other mods.My best 60ft on slicks was 1.73 so I didnt loose any low end power by using the zz4 cam.I used the zz4 retainers and springs and it cleared my valve guides just fine. The zz4 retainers are shorter then stock retainers so they give you more guide clearance. Also I have the stock chip so I dont have any Idea why you think it wont work! It worked great for me!! Its been in my car for 90,000 miles so far and I havent had one problem with the camshaft or the valve train. I would just check and make sure that the new retainers clear the guides to be safe but it worked fine for me without getting the guides cut down.
Old Feb 13, 2003 | 11:50 PM
REDZ28's Avatar
message me if you have any more questions.
Old Feb 14, 2003 | 12:07 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
HAHAHAHAHAHA
Ya man, if you want to go fast you MUST build a motor up ALL at the same time.
Anyway, I'll get those labels on the lifters for ya and try to get the cam to Steve. (ponyeater)
-Trevor (ZZ4 GTA everywhere else)
Old Feb 15, 2003 | 12:22 PM
Car: 1991 RS B4C
Engine: Stock 350
Hey ZZ4 GTA please explain to my wife that I need to drop the fast-burn 383 in the camaro. She doesn't think that I need to go any faster. Ain't that some crap. Looking foward to hooking up with you and ponyeater soon.
Old Feb 15, 2003 | 03:07 PM
Nasty_Bird_'90's Avatar
Ive got a zz4 cam in the motor thats going in my car this weekend. Hope it works out!
You guys hang out with Steve (ponyeater)? I know him. I put the 12 bolt in his car. We should all go cruise sometime and see who's got the fastest zz4 cammed car
Old Feb 15, 2003 | 11:25 PM
Car: 1991 RS B4C
Engine: Stock 350
Good luck with the cam. Let me know how it works for you.
Old Feb 16, 2003 | 12:53 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Can anyone cough up the ZZ4 cam's specs?
Old Feb 16, 2003 | 01:25 AM
Z_Ghost's Avatar
I cleaned them up after cough them up.
208 221 .474" .510" 112
Old Feb 16, 2003 | 10:23 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
You guys hang out with Steve (ponyeater)? I know him. I put the clutch in his car. We should all go cruise sometime and see who's got the fastest zz4 cammed car
Sounds good to me. I put in something slightly larger than the ZZ4 though. like a CC306. If you still wanna line up we should do it soon b/c the HSR will be on before the end of the month.
Old Feb 18, 2003 | 09:50 PM
88 IROC BOB's Avatar
I am throwing around the same idea now. Putting in a cam something like a ZZ4 or Comp Cams 218/224, but I won't be able to put new heads on it. I would however go with new springs and roller rockers.
I've got an Accel Superram lower intake and AS&M LTR's. The only missing piece would be the heads.
I know I should wait till I can afford heads but at the rate I'm going it may take along time. I've got to rebuild the rearend this spring (not cheap to do on a 9 bolt).
To cam or not to cam?
Bob
Old Feb 19, 2003 | 08:48 AM
The 218/224 will definitely want some heads. If that's what you're going to end up doing in the long run, just wait a little longer and do it right the first time. You have the stock iron heads or aluminum?
Old Feb 19, 2003 | 09:23 AM
I'm running the stock iron heads right now.
Bob
Old Feb 19, 2003 | 02:34 PM
Bort62's Avatar
Gee, Ive got the 218/224 on a 110 LSA in my Tpi'ed Lg4 - and It Works just fine
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
