intake base comparison needed
Old Mar 10, 2003 | 03:08 PM
Mooose's Avatar
I searched this site, but didn't "readily" find an answer to this. Can somebody provide a comparison between Edelbrock/Accel/TPIS Bigmouth intake bases? They are all comparably priced so I'm wondering which has the best volumetric efficiency. I can't find CFM info for these anyplace. Thanks in advance for anybody who knows this.
Scott
89 Pontiac Firebird Formula 350 (L98)
Old Mar 10, 2003 | 04:14 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
IMHO, the Accel and TPIS bases are more
refined (QC) and are ported for high flow.
The Edelbrock base may be a little rougher
and you would have to port it yourself for
max flow. (The price should reflect this IIRC,
the Edelbrock was $100 less than the others?)
HTH
mike
Old Mar 10, 2003 | 08:53 PM
1991 RS 305's Avatar
Usually you get what you pay for, sometimes not. Probably all good units, but I hear Edelbrocks Q.C. leaves a bit to be desired.
I'm wondering which flows best / is best too. Anybody know this,man?
:rockon:
Old Mar 11, 2003 | 08:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Posts over at corvetteforum.com have said that the accel and TPIS flow about the same, with the accel having the advantage of containing enough material to be ported even further.
Old Mar 11, 2003 | 08:27 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I agree, that is what I have read. It was a couple bucks cheaper to get the base from TPIS this one time. I usually hate purchasing anything from TPIS, they are too expensive for what they have.
Old Mar 12, 2003 | 04:29 PM
rezinn's Avatar
Check your TPiS base on the bottom for a number and look that up at edelbrocks website
Old Mar 13, 2003 | 09:18 AM
Jim85IROC's Avatar
It's no secret that the TPIS base is a ported edelbrock unit.
Old Mar 13, 2003 | 02:13 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i hate tpis
Old Mar 13, 2003 | 03:03 PM
jeffsbluez's Avatar
Car: 91 z28
The TPIS base comes with a stock intake port size. You have to pay $80.00 extra to get a 1205 port size. The Accel base comes with a much better port size. Why spend 400-500 dollars for a stock port. Just my .02
Old Mar 15, 2003 | 12:16 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
A long time ago, when I was shopping for an intake base, I e-mailed TPIS and asked them what set their Big Mouth base apart from the Edelbrock and Accel pieces. Their response was basically that I would have a hard time telling the difference between the three. I posted their response on the board - it is probably in the archives somewhere. I don't think they liked that - they stopped answering my e-mails after I did it.
I don't like TPIS either. I have the Edelbrock base - I have no complaints.
Old Mar 16, 2003 | 09:54 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I got these numbers off the corvette forum.
TPI, stock base, stock runners, 48mm - 185 cfm
TPI, Accel base, large tubes, lots of porting, 52mm - 212 cfm
SuperRam with unported Edelbrock base, 52mm tb - 224 cfm
SR with unported Accel base, 52mm tb - 233 cfm
Next Both bases were heavily massaged, with mild port work to the runners.
SR with Edlebrock base, 58mm tb - 256 cfm
SR with Accel base, 58mm tb - 259 cfm
Lots of porting,
SR with Accel base, massive work throughout - 278 cfm.
1992rs/ss
Jan 31, 2025 05:10 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
