those with lt4 hot cam
Old Mar 23, 2003 | 08:04 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
how lummpy is it and what is your idel set to, what is the power range. on top of that what do you get for mpg. i am thinking or using this cam and i would like to know what i am geting in to.
Old Mar 23, 2003 | 09:44 PM
ZZ405's Avatar
Car: 89 IROC
Engine: ZZ4
hot cam
It idles around 725 with almost no lump in my 89 IROC. I have no idea what the mpg is since I installed 3.73s at the same time and haven't checked it since.
Old Mar 24, 2003 | 09:36 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I have my idle speed set to 650 rpm in gear, and it lumps quite a bit. It's obvious that it's not stock. As far as powerband goes check the dyno listed in my sig. I usually get 16-18 mpg around town and 22 on the highway.
Old Mar 24, 2003 | 10:06 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
My idle is about 700 rpm and it sounds far from stock. I get alot of thumbs up at stoplights....
Old Mar 24, 2003 | 10:41 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
Hey RU-QWIK, is yours in a 305 or 350? What kind of tuning did you have to get? I'm having problems all over with mine, just trying to figure out what i didn't do, should have done, and should do.
Old Mar 24, 2003 | 10:55 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Mine currently is a 355... I had a board member , Kevin91Z burn a chip for it a long while back, but it needs to be updated badly. I plan to add an Accel DFI in the near future , so the tuning will be much easier.
Old Mar 25, 2003 | 01:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Mine idles around 725 rpms, gets 16-17 MPG in the city and 22-25 MPG on the highway, and required extensive work to the computer chip to get it that far. Power numbers, mods, and timeslips is in my signature.
Old Mar 25, 2003 | 06:12 AM
S10Wildside's Avatar
Here's a video of my L98 with the LT4 HOT cam. Idle is about 600.
I've got dual flowmaster deltaflow 50 series.
http://www.s10wildside.com/movies/IdleAtPipes.wmv
Old Mar 25, 2003 | 11:22 AM
so far, my idle when warm is about 650 rpm, all with out tuning, low vacuum, and running rich and timing very advanced. I think i have some valves not seating totally, so i'm getting pretty low compression. still have some bugs to work out, but should be ready to go soon. I'll tell you one thing, it certainly doesn't sound like a 305.
Old Mar 26, 2003 | 09:28 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Lumpy idle at 700rpm. 13mpg city/25mpg highway running MAF, hoping for a few more city with the SD swap. Can't comment on the powerband cuz of the stock tpi.
f-bodyz28
Sep 2, 2015 05:03 PM
theurge
Aug 21, 2015 12:46 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
