HELP? will 89-92 throttle body work on 88 older tpi?
Old Apr 16, 2003 | 01:04 PM
88irock's Avatar
HELP? will 89-92 tpi throttle body work on 88 older tpi?
Guys, will an 89-92 TB work on an 88 or older TPI setup? Is there a difference in them? I thought the only differences was in the MAF vs speed density stuff. Help please. Looking to buy a TB but want to make sure it will work on my car first.
Old Apr 16, 2003 | 01:52 PM
88irock's Avatar
Anyone?
Old Apr 16, 2003 | 02:03 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Don't quote me on this, but I think there are only subtle differences between the years. If you are asking if it will bolt up, yes it will. Will it run? yes. Will it run properly? I don't know. Try running a search because I believe this topic has been brought up before. Hope that helps.
Old Apr 16, 2003 | 02:13 PM
88irock's Avatar
Thanks, I'll try a search too...
Old Apr 16, 2003 | 02:37 PM
No problem... I just looked at some of summit's throttle bodies they carry, and they are listing different part numbers for those years... maybe there is a bigger difference, but I'm not positive. Sorry I can't be of more help.
Old Apr 16, 2003 | 02:41 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I'm wondering if the differences are in vacuum ports, etc. Aren't the pre-'88 cars MAF and the '89-'92 cars speed density?
Old Apr 16, 2003 | 03:07 PM
I thought '90-92 were SD and '89 older were MAF, but I could be wrong. The tech at summit seems to think that's the reason why they are different. I know that there IS a difference in them, but for the life of me I can't remember what it is.
Old Apr 17, 2003 | 12:19 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
https://www.thirdgen.org/techbb2/sho...+Throttle+Body
Check that out....you'll find alot of the answers there....
Old Apr 17, 2003 | 07:35 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You can connect the throttle cable for your 85-88 to the 89-92 throttle body where the cruise control should go. Or you could just go buy a throttle cable for a 89-92 car.
Old Apr 17, 2003 | 09:16 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
thats exactly what i did,like said above,i have a 90 on my 87 setup.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
