tpi damage
Old May 1, 2003 | 03:27 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
tpi damage
i locked up my 350 tpi and this is what it true hell looks like....
Old May 1, 2003 | 03:29 PM
demon138's Avatar
Old May 1, 2003 | 03:30 PM
demon138's Avatar
Old May 1, 2003 | 04:01 PM
Thirdgen86TA's Avatar
How did that happen?
Old May 1, 2003 | 04:28 PM
383 rocket bird's Avatar
WoW i have seen a lot and let me tell you that is one of the best, or the worst depending how you look at it.
Old May 1, 2003 | 06:39 PM
f0rmula350's Avatar
holy **** what the hell happened?
Old May 1, 2003 | 06:52 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
How many R's did it take to do this?
Old May 1, 2003 | 06:59 PM
demon138's Avatar
i had a small oil leak i "thought" i fixed but also cuz i like to really drive my car. i really dont mind it breaking except for the price to fix it cuz i like to work on it. i threw 4 rods and burned up a crank journal. now im going to build a 383 stroker with the block . ............by the way whats an "R"?
Old May 1, 2003 | 07:06 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
R's is RPM's. Make sure you use ARP rod bolts on the 383.
Old May 1, 2003 | 07:11 PM
demon138's Avatar
oh the rpms werent high at all i was driving home going 70 in overdrive so i guess that makes the rpm's around 2500-3000 rpm
Old May 1, 2003 | 10:58 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Make sure you get that block check out by a very competent machine shop or engine builder. With the damage to the rest of the rotating assembly I wouldn't be surprised if the block has some damage as well. It smoked a rod journal or main journal? Not trying to make your situation any worse, just telling you what I think.
Old May 1, 2003 | 11:58 PM
SMOKY21's Avatar
Car: 85 s-10 soon
Engine: just a small block
Transmission: th350
Throw that block away 2bolt mains arnt worth much for perfomance. Go find a nice 4bolt main so it can handle over 400 hp reliably.
Old May 2, 2003 | 12:23 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
2 bolt blocks have seen 500 horse without breakage,
2 bolts will hold 450 in its sleep..
u should have the block gone through thoroughly
Old May 2, 2003 | 12:36 PM
sudolg's Avatar
Wow. Very nice. This gives you a nice excuse to build a new motor. I would say this was spinning at 7-8K or you ran out of oil...
Old May 2, 2003 | 01:10 PM
BORLAZ06's Avatar
WOW!
Old May 2, 2003 | 02:06 PM
demon138's Avatar
this is the only damage the block got is the block still good?
Old May 2, 2003 | 02:09 PM
demon138's Avatar
heres a piston
Old May 2, 2003 | 02:53 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
So you want to make a 383 out of that block. I'd strongly suggest another block. The longer stroke of a 383 will bring the piston even closer to that damaged area.
Old May 2, 2003 | 03:49 PM
fakezcar's Avatar
I agree with rick and toss that scrap iron away. I wouldn't chance building a new motor on that block. And just to chime in...I've seen a two-bolt make 650 flywheel horse and run all day long. Much more and you do need a four bolt or have the machine shop install splayed four bolt caps on your two bolt block. especially since two bolts are a dime a dozen. Just my $.02.
Chris
Old May 2, 2003 | 03:52 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The fact that the rods let go like that, and that rods letting go are the most common failure mechanism are all the evidence a laymen should need to realize that the main caps are generally not the weak spot in a street 4" bore SBC.
Old May 2, 2003 | 03:57 PM
fakezcar's Avatar
exactly the point I was trying to make. Just please make sure you get some good rods and arp bolts.
Chris
Old May 2, 2003 | 09:09 PM
Ragtop89's Avatar
That is impressive!
How'd the car act when she locked up?
Throw the *** end around?
Old May 3, 2003 | 04:43 AM
demon138's Avatar
naw it just died and started rolling
Old May 3, 2003 | 05:08 AM
85TPI400's Avatar
Man, I have seen this to often. As far as stroking that block, I would forget about that. However if you ever wanted to rebuild it as a 350 again, I would take it to a machinist and have him clean and mag it. Unless you clean it and see any cracks off the bat. I have seen a few times where when the engine throws or two it leaves obvious or hairline cracks in the cylinders walls.
Good luck with a rebuild!
Old May 3, 2003 | 02:44 PM
FstBrd6point3's Avatar
get a two bolt block with splayed caps, they are stonger than the 4-bolts. 4-bolt blocks are over-rated... but I still had to have one for myself :-D lol
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
