cam
Old May 14, 2003 | 03:21 PM
91blackgta's Avatar
cam
Anyone here using a comp cam. I am looking at the 12-404-4. http://www.compcams.com/catalog/082_083.html
here are the specs.-
duration- 222 intake
- 226 exhaust
lift- 0.464 intake and exhaust
lobe separtion- 114 degrees
looks good to me, i can do prom adjustments so don't worry about that. just curious what people thought that have used it.
or is there a better cam?
Old May 15, 2003 | 10:15 PM
bigals87z28's Avatar
Car: Check The Sig
i feel like a cam *****, but the ZZ4 cam will work better. Its got a little more lift and i belive the durration is the same, if not a bit bigger. There cheap, and you could find one easily. Most engine builders use the ZZ4 crate motor as a base, and throw out the cam for a bigger, race type cam. Thats how i got mine. anyway, good luck with your car... wish i had a 350!
Alex
Old May 16, 2003 | 04:08 AM
85TPI400's Avatar
I know the ZZ4 does not have the same duration, off the top of my head I believe the ZZ4 cam only has 208 in. 221 ex duration, does have higher lift at around .473 in. .509 ex.
However this ZZ4 is a roller cam, he is talking about a flat tappet.
Anyway I think the Comp cam mentioned although it is a flat tappet and has less lift, would outperform the ZZ4 by a bit.
Just my opinion though!
Old May 16, 2003 | 08:26 AM
91blackgta's Avatar
I'm trying to go with a non-roller hydraulic cam because the block is a 73 model. It would prolly cost a lot more to go roller. Is the zz4 cam roller?:hail:
Old May 17, 2003 | 02:06 AM
85TPI400's Avatar
The ZZ4 cam is a roller cam, I am absolutely, 100 percent positive that it is definitely a roller cam!
Old May 17, 2003 | 11:46 AM
Car: Check The Sig
ops sorry...
Old May 17, 2003 | 08:55 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
was a ZZ-3 a non roller cam engine, I believe it was the predecessor of the ZZ-4, but it used a two piece main seal, and I think it was a 330 hp engine, I may be wrong, but knowing my luck I am definately wrong
Old May 18, 2003 | 02:35 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
ZZ4 = 208/221* and 474/510 lift.
I would also go w/ a bigger cam. All this depends on what else your doing w/ the car. Heads, intake, nitrous, daily drive, drag race, circle track? There is no perfect cam for everything, just different ones that work better then others in different situations (motors).
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
