Lean Fuel Question:
Old May 22, 2003 | 10:45 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Lean Fuel Question:
Last time I took my car to the dyno, I found that I was running very, very lean. I think I hit 16.2 on the A/F Ratio. So I did some testing, and my pump is going out. I am having it replaced with a 255lph pump this weekend while I'm out of town.
Here is my question:
I am running 24# SVO injectors which are rated at a lower psi. This would mean that an equivalant 24# from Accel/Bosch would run lower fuel than the 24# from SVO. I can't get my AFPR to turn below 50 psi. So I changed my injector constants to 27.2, this way it makes up for the 39.5psi that the SVOs are tested for, and the 50psi that my car is running at.
Did I do this correctly? Does the AFPR, when turned higher, make a difference to how much fuel is added to the engine, or just a better atomization?
If it doesn't add more fuel, then I need to change the constants to the difference of the injectors, not the psi and the injectors. My BLMs are closer to 128 when I changed them to 27.2, they were at 108 for most of the driving.
Thanks for looking.
-daniel
Old May 22, 2003 | 12:18 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
raising pressure does add fuel.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
