Power loss over 3000 RPMS?
Old Jun 22, 2003 | 04:58 PM
CarAteMyMoney's Avatar
Anyone know what might cause a power loss over 3000 rpms? Also it seems hesitant to rev in that area
but the thing still leaves 20 foot pairs of tracks from hitting the gas at a stop sign
Old Jun 22, 2003 | 05:29 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
yea, the stock tpi system on a 350 can cause power loss over 3k RPM. Your best bet would be to switch over to a different induction system like the Holley Stealth Ram. If you don't have the money for that kind of setup you could always port out your stock plenum runners and base (depending on the fact that you actually do have tpi). Post a little more info about your car so we can help diagnose the problem.
Old Jun 22, 2003 | 05:31 PM
what i meant by power loss was that this car feels much less powerful than any of my other L98 TPI cars
Old Jun 22, 2003 | 05:47 PM
nikh23's Avatar
when was the last time you did a tuneup?
Old Jun 22, 2003 | 06:29 PM
when i got the car, in november. new cap, rotor, wires, 02 sensor...
i noticed on the scanner that my 02 voltage jumps from .3 to.8 back and forth and doesnt usually come close to .45 volts if that helps
im thinking maybe timing, leaky injector or bad ignition module could be the culprit but im looking for suggestions
Old Jun 22, 2003 | 10:32 PM
nikh23's Avatar
did you change the ignition coil? I don't know if that'd be teh sole culprit but it def can't hurt
Old Jun 23, 2003 | 03:10 PM
yup swapped in the coil from my other car, no change
Old Jun 23, 2003 | 03:33 PM
nikh23's Avatar
check your fuel pressure
Old Jun 23, 2003 | 05:29 PM
hmm, good idea! what should it be? like 42 at idle right?
what about under load? is there any way to check it other than on a dyno?
Old Jun 23, 2003 | 06:15 PM
Spdfrk1990's Avatar
maybe that coil is bad my car use to do that until i changed my coil
Old Jun 23, 2003 | 11:07 PM
nikh23's Avatar
I think thats correct for the L98 motor, not entirely sure but its definitely in that range. dyno is the only real way to check it at WOT, or you could bring it to a track and try to test/tune it that way. While you're at it pick up an adjustable one, might as well right?
Old Jun 24, 2003 | 08:36 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
...not to insult you....
I don't know if you went into this, but....
Have you checked your fuel filter lately??? I had a similar problem with my '92, the fuel filter was dirty and it wouldn't allow enough fuel to enter the injectors. I didn't notice if you mentioned checking it, sorry if you did.
Either way, sounds to me like your "leaning out" the motor. I'ld go after the fuel delivery system, then check out ignition.
Just a thought, keep us informed
Old Jun 24, 2003 | 09:54 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Check for a clogged cat. Low will still be good but top end will suffer.
Old Jun 24, 2003 | 11:24 PM
i'll do the fuel filter tomorrow.
i have one cat per side - how should I go about checking them?
Old Jun 25, 2003 | 12:53 AM
nikh23's Avatar
would a bad cat really cause that much power loss? I guess you could check to see if the outside of the cat is all burned and charred looking, thats a good indication that cat is done. Also if your exhaust smells like rotten eggs. Best way is to jam a pipe through them and reattach them back up to your exhaust and call it done hehe.
Old Jun 25, 2003 | 06:23 AM
Spdfrk1990's Avatar
i had a cat go bad on a 4 cylinder car b4 and it hardly had ne power till it got fixed
Old Jun 25, 2003 | 08:59 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
A bad cat will kill all upper RPM power if it is clogged. I had a 350 GTA that had a bad cat and it would launch ok but then quickly run out of breath. With the bad cat it ran the quarter in 15.97 at 85 MPH. Once I replaced the cat it ran 15.15 at 92 MPH and reved nicely to 5000 RPM.
Old Jun 26, 2003 | 03:27 PM
fuel filter helped a little, but not much.. it's still not how it should be
within the next 2 weeks ill be doing the ignition module, injectors, timing, and whatever other little crap i can think of
i noticed that the return line near the fuel filter is pinched, but not too bad, would that have anything to do with it?
Old Jun 26, 2003 | 03:45 PM
nikh23's Avatar
that can definitely be the problem. i'd get that fixed before anythign else.
Old Jun 26, 2003 | 09:17 PM
Car: 92 Camaro RS
Quite simply, I think that MAY be your only problem, I'ld still say get an adjustible fuel pressure regulator and a guage, I say that your problem is Fuel related.
Old Jun 27, 2003 | 07:02 PM
wouldn't a pinched return line hurt off-idle power more than high rpm? since more fuel would pump into the engine
wait a sec... how could a pinched return line hurt the performance, anyway? isnt it all regulated?
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
E Rod
Aug 28, 2015 05:17 AM
Bradsaundry
Aug 12, 2015 12:34 AM
