TPI swap
Old Jun 29, 2003 | 08:38 PM
novakm's Avatar
TPI swap
A little help please...
I put TPI into my 71 Chevelle.
Engine has mild cam
I bought a nex AUJP chip from GM to start
Junkyard harness
new 24lb injectors
When I turn the key, it jumps to life and then immediately dies. Does not throw any codes. Since it fires, I know there is spark and the injectors work
If I keep the starter engaged, it sound like it is running, but dies when I let go of key
Opening throttle makes it jump to life at a higher rpm, but it dies just as fast.
I took out the Eprom to force limp mode, and it acts exactly the same.
Vats has been disabled..(by me, I have pocket programmer, Moats' adapter, and moates' scanner software.)
Tried messing with ve tables..+10 and -10 across the board
Nothing seems to make a difference.
Obviously either the ecu is fried or I hooked something up wrong.
Any ideas?
Mike
Old Jun 29, 2003 | 08:45 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Did you check your fuel pressure ??
Old Jun 30, 2003 | 10:15 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what type of TPI is it?MAF or Speed Denisty?
sounds like a problem i had with my 91 Bird
check your vacume going to the MAP sensor.make sure you have a dedicated vacume sourse for the MAP.
Old Jun 30, 2003 | 11:55 AM
novakm's Avatar
Thanks...
I have not had a gage on the fuel pressure yet, But I can feel it in the hose when the pump goes on. I know some fuel is getting up, because of the initial VROOOM.. when I turn the key. As soon as I let go of the key it's like I shut it off. Just dies. I need to find a fuel pressure tester.
The intake is from an 87, but I am using a '730 SD ecm. Yes, the MAP sensor is on a dedicated line.
Watching vacuum on the scanner, it starts at 98 before I try to start. As it catches, it drops to about 40, but does not run long enough to draw more than that. With the carb, I would pull 15-18" vac.
Old Jun 30, 2003 | 01:03 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
Do you have the fuel pump switch hooked up? It is a sender on the back of the block. If it is not hooked up, the ECM will see no oil pressure and will then shut off the fuel pump. The ECM ignores the oil pressure when in crank mode, allowing the engine to start, and run for a few seconds.
jmiller
Old Jun 30, 2003 | 02:08 PM
91banditt2's Avatar
Engine: 5.7 HSR
could be a bad IAC
Old Jun 30, 2003 | 05:13 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
When you said that you tried to start it with the throttle open and it still died, did you keep the throttle open or let if go? I am just thinking about maybe the IAC or minimum air not set right. Sounds like a similar problem I once had. Good luck...
Old Jun 30, 2003 | 08:19 PM
novakm's Avatar
I found the problem!
I feel like an idiot!
ECM needs an ignition feed. I spliced into the distributor feed. Distributor is fed with a resistance wire that is bypassed when the key is turned for starting.
While cranking I had a solid 12v. soon as I let the key go, voltage dropped just enough to keep it from running. once the engine died, the coil was not drawing as much current, so I had 12v again, so no codes or other indication of problem...
Last question, Should I hook the coil to the resistance wire that fed the old distributor and the ECM feed to a good ignition source, or should I bypass the resistance wire and connect the coil to ignition with no resistance?
Do '90 TPI camaros use resistance wire in the ignition coil circuit?
Thanks guys!
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
