Does it matter what year MAF
Old Jul 7, 2003 | 04:02 PM
mike81monte's Avatar
I recently bought a TPI unit to try on my monte my question is can any maf from a tpi from 86-89 work. My Tpi is from an 88 Iroc 350 , i know someone selling an 89 maf sensor but wanted to check if it will work fine. Thanks
Old Jul 7, 2003 | 04:44 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, all TPI Maf's are the same for both 305/350's all years.
Old Jul 10, 2003 | 01:01 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
You are incorrect. In '85 the MAF was an analog style. 86+ was not.
https://www.thirdgen.org/techbb2/sho...hreadid=183262
Old Jul 10, 2003 | 07:11 AM
DJP87Z28's Avatar
Ok, your right I forgot about the Bastard 1985 ECM year.
Otherwise the Wells will work on later TPI Maf cars.
Old Jul 10, 2003 | 07:37 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
An 85 MAF will still work on 86-89 cars. The 86-89 MAFs just won't work on the 85s.
Old Jul 10, 2003 | 08:29 PM
Even though I miss her, I'm glad my '85 is in the boneyard. '87 all the way! :O)
Old Jul 11, 2003 | 10:30 AM
Thanks Guys
Old Jul 12, 2003 | 01:31 PM
OutsiderIROC-Z's Avatar
I have an MAS on my 85 IROC that is off of a 1988 IROC. I have not noticed any problems up to this point. What should I look for?
Old Jul 14, 2003 | 08:19 AM
Jim85IROC's Avatar
I can't understand why the 88 MAF even works on your car. The 85 computer has absolutely no way of recognizing the signal from the 88 sensor. I tried the sensor from my 88 GTA on my IROC before I swapped to a newer ECM, and it had no idea that there was even a MAF plugged in.
Old Jul 14, 2003 | 10:55 AM
I don't know either. It runs just fine, other than being a bit lean after I put the headers on it.
chazman
Aug 28, 2018 03:25 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
