Very depressing news
Old Jul 24, 2003 | 01:58 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I spoke w/ a machinist about my combo and he pluged it into a program like desktop dyno. He said it doesn't inflate the numbers as much. Well I hope it didn't b/c it only showed a little over 320hp at the crank. I was thinking over 400 w/o to much trouble.
Anyway could someone plug this into DD2000 so I can get a second opinion.
Holley stealth ram
cc306
Portopline 200cc
on a 355 w/ 10.25:1
Any reply would be great, thanks.
Old Jul 24, 2003 | 02:45 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
gimme a minute.
Old Jul 24, 2003 | 02:55 PM
mastrdrver's Avatar
I dont know what he is using but, assuming tuning is right, I think you will make more then 400 crank hp with that setup.
Old Jul 24, 2003 | 03:07 PM
Mutiny32's Avatar
DD2K is saying 400.
Old Jul 24, 2003 | 03:09 PM
Mutiny32's Avatar
I couldn't find all the specs I needed for the cam, so I winged it a little.
Old Jul 24, 2003 | 09:47 PM
86 IROC's Avatar
Just bench racing here I suppose, but I got 468 HP & 418 TQ. I used the flow #'s for those heads right off of their web site, and know the cam specs by heart . (see sig) I'd guess the HP to be about 10-15 to the high side and the TQ #'s to be 25-35 shy of what they will truly be.
Your best bet it to test it on an engine dyno prior to putting it in the car if you are worried. Persoanlly I wouldn't sweat it if I were you.
Old Jul 25, 2003 | 06:16 AM
Doug Flynn's Avatar
If that didn't make 400 flywheel HP then something is wrong. That should make close to 320 at the wheels if the heads are clean and you have a good exhaust and it is tuned properly.
Old Jul 25, 2003 | 09:07 PM
grumpyvette's Avatar
swap to a crower #00471 hydrolic roller cam and look at the results
http://www.crower.com/misc/cam_spec/...00471&x=44&y=6
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
scottmoyer
Sep 7, 2015 07:06 PM
Justin69
Aug 31, 2015 11:31 AM
theshackle
Aug 31, 2015 10:47 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
