Going to port intake soon....what are the gaskets?
Old Aug 6, 2003 | 12:31 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I was searching around and I am not sure on which gaskets to get. I want to get some that will give me an idea of where to port the intake.
I am going to only port the plenum and runners, not the base.
A part number and a place to buy them would be appreciated.
Thanks,
Brian
Old Aug 7, 2003 | 03:22 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Come on guys, I know 80% of you know which ones I am talking about. I just need the part number.
Brian
Old Aug 7, 2003 | 03:29 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The big mouth gaskets are sold by tpi's. Look under tpi gaskets
here
Old Aug 7, 2003 | 03:46 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Sweet! Thanks man.
Brian
Old Aug 7, 2003 | 06:17 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If you're not touching the base and using the stock runners, no reason to use anything but a stock replacement set and radius transitions from plenum to runner.
Just bolt one runner on the plenum and look through from the other side.
Once you take out as much as you can, keeping in mind there's not a lot you can do to the runner, if the stock gasket hangs into the hole, just trim with an Exacto knife.
Old Aug 7, 2003 | 10:11 PM
xmind2006's Avatar
Car: '86 Iroc-z28
I got all stock replacement gaskets for ~$15 shipped from:
\http://www.pickproparts.com/default.aspx
Old Aug 7, 2003 | 10:36 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I was going to port the base too but I was told by several people that it is a huge pain in the a$$ and that it is better to spend the cash on a new one then go through the hassle of doing it myself. Is there any truth to this? If I can get a noticable amount of HP I will do it and save the cash.
So if I keep the stock runners it isnt really going to do anything much to port the plenum? and base?
Brian
Old Aug 8, 2003 | 08:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There are some gains to be had with porting the base, but nothing that will set you back in your seat.
If you have the $$, upgrade the base and runners, then port your plenum to match the runners.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
