no power
Old Aug 13, 2003 | 03:17 AM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
no power
this is weird ok,I usually stay off the freeway if I can,but in So-Cal its nearly impossible,my problem is when i'm going on a straight flat freeway the car has good power,but if the freeway is going uphill my car nearly dies,i'll be going 75 before the incline and half way uphill i'm at 50 at WOT and the car shakes!anybody know what is causing this?Thanks
Old Aug 13, 2003 | 12:57 PM
kevinc's Avatar
Car: 1982 Z28
How old is your fuel filter?
The symptoms sound like fuel delivery, so focus on ruling out the filter (easy swap) and then the fuel pump. A pressure gauge will tell you what's going on.
Old Aug 14, 2003 | 01:17 AM
JohnS's Avatar
Engine: 3.5 V6
i changed the fuel filter already,i've only had the car 1year,so i'm not sure when the pump was last changed.sometimes when i start up in the morning it will rev @1500rpm's then nearly stall,then back to 1500 and nearly stall again,but after that it runs fine.also the SES light comes on after about 20 minutes on the freeway,then turn the car off and back on,and SES doesn't come back on.
Old Aug 14, 2003 | 07:57 AM
kevinc's Avatar
Car: 1982 Z28
Let us know what the pressure gauge says.
Old Aug 15, 2003 | 03:07 AM
JohnS's Avatar
Engine: 3.5 V6
i don't have a pressure gauge,i'll see this weekend if i can find a cheap one or see if any friends have one.
Old Aug 15, 2003 | 05:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Check your codes to be sure but this particular order for the light is usually indicative of an O2 sensor. I don't see how an O2 sensor would cause the problems your having, though. Maybe you have 2 problems.
Old Aug 15, 2003 | 07:12 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
um, maybe its staying in 5th," if u have a 5th?" does it ever have any downshifting problems or anything?
Old Aug 15, 2003 | 11:40 PM
JohnS's Avatar
Engine: 3.5 V6
i pretty sure the o2 is bad,i have a very strong gas smell when i turn the car off and bad gas milage.transmission shifts ok,its a little jerky whenever i touch the gas,normal street driving its fine in D,but if i drive around in OD it feels like my old 2.8 V6.could the overdrive gear be worn out?Thanks for all the help
Old Aug 16, 2003 | 08:22 AM
kevinc's Avatar
Car: 1982 Z28
Old Aug 19, 2003 | 09:01 AM
Pimpinfolyfe's Avatar
my car has the problem about the SES light its my EGR valve...nothin big and worth replacing...just puts exhaust into ur intake...i dont htink ur SES code has anything to do with ur motor goin up hill...
Old Aug 19, 2003 | 11:55 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
Sounds like the ignition module is going.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
