help choosing combo for low 13 high 12's which heads?
Old Aug 13, 2003 | 08:04 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
my delima is the combo i have in my sig. runs perfect. but i have a set of ported edelbrock 6085's on my workbench.my choices r:
1. change the intake from what i have now to a superam and leave the rest alone.
2. install edelbrock heads under the intake i have now(see sig.)
3. wait till the funding is there to do both
obviously you would say DO IT ALL. but my other question is r the 6085's so much better than the S/R torkers that warrant the headache of changing over, i can put a superam on top of the Torkers? my goal...... low 13 high 12's. and i got to pass CT. emissions is it possible?
Old Aug 14, 2003 | 06:26 PM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
geez alittle help... trust me i did a search.
Old Aug 14, 2003 | 06:31 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I'd do the heads, although I don't have experience with those Edelbrock's, so I don't know if or how much better they are over the Torkers.
The cam you have seems better suited to long tube runners than a SR. And if your looking for high 12's low 13's, you don't need a SR to get there. I'd save the SR money for something else.
Old Aug 14, 2003 | 09:09 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Do you have any track info on the current combo? If you knew what you run now, it is much easier to figure out how much more hp you need.
I agree with Buckeye about the cam, it is small for a SR, perfect for the LTR, and your stall suites the LTR setup better.
I'd imagine those Edelbrock heads are better than the torquers, how much, ?. But its gotta be an improvement, save weight, and you already have them.
Low 13s are easy, with what you have already you should be able to hit that IMO.
Old Aug 15, 2003 | 09:32 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The Torquer heads will get you into the high 12's with the SR, I did it myself along with a Lunati 218-226 cam. The only advantage on the E-brock heads is lighter weight, they don't flow that much better.
Old Aug 15, 2003 | 11:33 AM
eddie89TA's Avatar
Car: 89GTA
Axle/Gears: B/W3:27
rick: what exact combo did u have to brake into the 12's 355? 700r4? gear? intake? thanks.. i really dont want to disturb a perfect running combo (heads). if it isnt worth the effort. anf i can install a new intake instead.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
