Wells MAF Code 36
Old Sep 4, 2003 | 08:45 AM
nes_t_383's Avatar
Wells MAF Code 36
I tried doing a search for this but I couldn't find an answer that really satisfied me. I have recently installed a Wells SU145 MAF sensor on my 89 GTA. Now, I am pulling a code 36. Now I know that the Wells unit does not use the burn off feature like the Bosch ones do. So, my question is that will the code 36 affect anything besides the fact that it creates the little annoying light in my gauge cluster? How can I fix this? (and no, I don't burn my own eproms so I can't change it that way)
Thanx.
Old Sep 4, 2003 | 11:13 AM
Morley's Avatar
I thought the Wells MAF was supposed to have circuitry that emulated the burn off function to prevent this code from being set. You may have a bumm MAF.
Old Sep 4, 2003 | 11:57 AM
nes_t_383's Avatar
Thanks. Does anyone else have this problem?
Old Sep 4, 2003 | 01:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I believe a faulty relay will still throw a 36 even with the Wells. Have you tried swapping the relay?
Old Sep 4, 2003 | 01:55 PM
nes_t_383's Avatar
No, i haven't tried swapping relays. The relay worked fine with my Bosch maf. But, would it really matter if the relay was malfunctioning with the Wells unit since there is no burn off???
Old Sep 4, 2003 | 02:36 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Does the ECM know it???? It will still throw codes from a faulty sensor. It happened with my Wells Maf.
Old Sep 4, 2003 | 02:39 PM
nes_t_383's Avatar
What I'm trying to say is will it affect drivability and performance?
Old Sep 5, 2003 | 01:29 AM
Morley's Avatar
That is a good question, the ECM may go into a routine where it ignores the MAF since it thinks it is malfunctioning, in that case it will affect drivability. But I don't know if it will ignore the MAF when that code is present.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Warlocksirix
Sep 3, 2015 12:26 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
