Overly low idle after clutch pushed in. Any ideas?
Old Sep 15, 2003 | 12:41 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Just yesterday a friend and I swapped out some injectors in my car. I have a 305 and put in 22#ers so my friend did some prom changes to compensate. We took it for a drive to log some data and when the clutch is pushed in the idle goes all the way down to 500 and sometimes it wants to die and other times it just dies . We looked at some of the obvious things like TPS, vaccum leaks, and the like but couldnt find anything. Anyone have any ideas at all on this? We were using Craig Moates software to log the data and noticed that the throttle % is WAY off but the reading on the TPS is right on.
I am at a loss for what it might be as well as my friend. If anyone has any ideas please let me know. Thanks a ton.
Old Sep 16, 2003 | 10:49 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Anyone have an idea?
Old Sep 16, 2003 | 02:00 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
May be bad injectors. Were they used?
Old Sep 16, 2003 | 04:44 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Actually they are in perfect shape. I had my friend at TPIS clean and flow match them and they read all within 2% of each other. He actually etched the numbers right on the injectors.
Old Sep 18, 2003 | 11:49 PM
Stevie's Avatar
Have you adjusted your "minimum air"? The little stop screw that sorta looks like an idle adjust screw on a carb? Here's how ya do it:
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Sep 19, 2003 | 01:08 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Thanks for that but that is the thing. It will idle right on after dropping to the 500 rpm mark. It is a 5 speed so it should sit right at 750. I am about to loose my mind on this one.
Old Sep 19, 2003 | 02:17 PM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Does the idle go down only when the car is stopped and the clutch is pushed in, or does it drop even when you are rolling and the clutch is pushed in?
If the idle only drops when you are at a dead stop, does putting it in neutral make the idle go back up?
Did your friend make any other adjustments on the chip other than compensating for the larger injectors?
Old Sep 19, 2003 | 03:44 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I notice it most when I am coming to a stop from driving and when the car is initially started. Also it doesnt matter if I have been driving for a while or not. The chip is perfect. We have checked over the prom and it is just as solid as can be for everything that is done to the car.
Forgot it does that no matter what is going on, whether I am sitting or rolling.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
lakeffect2
Aug 23, 2015 08:44 AM
zeitghaist
Aug 18, 2015 07:33 AM
