Should this happen?
Old Sep 18, 2003 | 03:40 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Should this happen?
I got a fuel pressure tester and hooked it up (no one ever mentioned having to remove the MAP!) Anyways, when revving the throttle at the TB, the pressure drops into the 30's. Someone told me this is not a good thing, and that it means that as I'm revving, although the engine wants more fuel its getting less. Is this true or is the situation normal? Thanks.
Old Sep 18, 2003 | 07:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Pressure should increase, when vacuum is lowered. i/e when throtle is opened...should maintain pressure once vacuum is stablized.
You sure you aren't noticing the drop when letting off the throttle?
Old Sep 18, 2003 | 07:55 PM
jamesbob02's Avatar
Car: 92 Z28
Yeah I was doing some research and found that pressure should drop during decel because vacuum raises. I don't know if this is what was happening or not, I won't get a chance to test again for a couple of days.
Just for reference when I get to test again though, but how much should my psi be increasing when I rev up, like a couple of psi or like 5-10 range?
Thanks.
Old Sep 19, 2003 | 05:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It's possible to see a 10psi swing, I'd guess (never really checked it out tough) from high vacuum to low vacuum.
Old Sep 19, 2003 | 05:55 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
leaky injectors **** me off!!!
Old Sep 19, 2003 | 08:18 PM
jamesbob02's Avatar
Car: 92 Z28
Mine are definitely not leaky, they're new. Now the heat is on the fuel pump,
Old Sep 19, 2003 | 08:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Suggest the filter first, if you suspect a flow problem.
Old Sep 19, 2003 | 09:22 PM
jamesbob02's Avatar
Car: 92 Z28
Replaced it recently too.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
