what intake gasket should I port match to?
Old Oct 22, 2003 | 01:56 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have the heads off my tpi 305 (88) and was wondering what intake gaskets yall are using/porting to. stock heads and intake base BTW.
Old Oct 22, 2003 | 06:20 PM
rezinn's Avatar
Using felpro 1205s with vette heads.
Old Oct 23, 2003 | 08:03 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
good to know -- thanks
(edit) oops looks like I cant use them because fel pro says not for 87 up iron heads.
Old Oct 23, 2003 | 09:25 AM
rezinn's Avatar
Old Oct 28, 2003 | 11:01 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have looked at all the fel-pro individual gaskets on summit but they all say "not for 87-up Iron heads"
What is the deal?
Also I still want the EGR to function so the exhaust crossover must be open...
Old Oct 28, 2003 | 11:27 AM
smithtc's Avatar
'89 engine...083 heads L98 cast iron.
I just went and bought a stock gasket set from Advanced Auto Parts. The intake gasket was a Felpro...but I don't know the part number. Haven't matched it to the intake yet. The gasket was bigger than my stock port entry...so, take that for what its worth. I opened the intake port on the head up. I'll just make sure my actual intake manifold port exit is smaller than my gasket.
HTH
Old Oct 28, 2003 | 04:57 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just ordered 1205's for mine. Wonder why they won't work w/ iron heads?, I have l98 iron. They don't have the heat crossover, but I am using a stealth ram, so that doesn't matter. Guess I'll find out when they come in. Anyone know why they wouldn't work???
Old Oct 29, 2003 | 07:37 AM
Car: 1971 Camaro
Engine: 427
Anyone know why 1205's won't work?
Old Oct 29, 2003 | 08:22 AM
TPIgirl's Avatar
Car: 89 Irocz
Engine: 350TPI $6E
I'm matching mine to a 1205 gasket as well. It's just because the center bolt holes don't line up. It's not a big deal and I'm just going to open the holes up.
Old Oct 29, 2003 | 06:47 PM
85TransAm406's Avatar
Car: 1985 Trans Am
You could open the bolt holes up, but the reason they are like that is that 1205s are intended for a larger runner head, i.e. my Sportsman IIs. When i lined up the 1205 on the runners on my heads, the intake won't even seal to them.
Old Oct 30, 2003 | 10:05 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
well I ordered the 1205s and I guess I will just enlarge the center 2 bolt holes and punch out the exhaust crossovers.
That picture you included TPIgirl is exactly what I needed -- thanks.
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89-S-dime
Aug 12, 2015 11:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
