Super ram and cam
Subscribe
Oct 23, 2003 | 10:23 PM
the car is a stock 88 350 iroc with headers 1.6rr. I just got the supper ram and wanted to know what would be a good cam. I did a search on this and know about the lpe 219 cam. If I port and polish the heads do you think that this cam is too big or not.
224/224
.555 w/ 1.6 rockers
Im changing the cam this week so some help is needed
Reply 0
Oct 23, 2003 | 10:26 PM
the car ran 14.44 @ 94 mph it has 2.77 rear end gears
Reply 0
Oct 24, 2003 | 12:51 AM
That cam would work fine, if the lobe seperation is about 112 with 2-4 degs adv. Seriously consider not porting the stock heads, it's just wasting yours or someone elses time. I know, I've tried porting iron heads. If you value your time on this earth, you won't want to waste it on these. If you had alum. vette heads, I'd say yeah go ahead. Save up for some TF's, Pro-Toplines, or Dart heads if you're on a budget or even look on ebay for some aft.mark. alum. heads.
Reply 0
Oct 24, 2003 | 01:54 AM
You'll need heads that flows good on the exhaust.....
Reply 0
Oct 25, 2003 | 05:08 PM
Is there a sertin year corvette head that I should get? Thanks for the help.
Reply 0
Oct 25, 2003 | 06:21 PM
OK, couple questions. The cam I got has a lift of .555 (with 1.6 rockers that I already have.) Will this hit the piston or cylinder wall if I use the thinner gasket? I want to use the thinner gasket to raise compression. I also orderd the valve springs to go with the cam. What else should I be worried about besides chip and no egr?
thanks for the help
Reply 0
Oct 26, 2003 | 03:22 PM
It probably won't hit the piston, but ...
Anyway, the stock heads probably won't support that much lift without machine the valveguides down.
You'll need decent springs too, so you'll have to machine the spring pockets for a larger diameter spring.
Since you'll have so much lift, and higher pressure springs, you'll need the rocker bosses machined down and tapped and install screw in studs, may as well run guideplates too and non-SA rockers.
So you're probably into a few hundred bucks at this point for heads as-is, that won't support the flow for the cam you've chosen and still haven't been machined yet for surfacing, valves, valve job, etc...not to mention many hours of porting.
Suggest you rethink your current plan with those heads...you're heading into mis-match territory.
Reply 0
Oct 29, 2003 | 12:30 AM
I know the afr heads are favored. Where does evryone get them? Also what other heads are there that ae a little cheaper?
Reply 0
Oct 29, 2003 | 07:31 PM
Quote:
The only place I've found them is www.flatlanderracing.com
-Rippin
Reply 0
Oct 29, 2003 | 09:11 PM
I run a lt4 hotcam with my superram on stock bottom end with AFR 190's performance is great. Plan on going to a cc306 when I stroke it though.
Reply 0
Oct 30, 2003 | 05:00 PM
You can get AFR heads directly from AFR www.airflowresearch.com
their prices are usually the best, I got mine there.
I would avoid the LT4 hot cam with the SR, I tried it, and it did work ok, but you can do much better. If you already have the 224/224 cam use it, it should work great. I was going to use that same one.
still though, do the heads too.
Reply 0
Oct 30, 2003 | 05:08 PM
Bigger is always better, I went with it due to emissions. I do plan on going bigger when I move back to San Antonio though.
Reply 0
Oct 30, 2003 | 05:18 PM
It's not so much the size, the SR likes single pattern cams, while the hot cam is a split duration.
I did alright with it 107 mph, but I was expecting another 20-30 hp just by going to the 224/224 cam.
when you moving to SA?
Reply 0
Oct 30, 2003 | 05:22 PM
Mine seems to pull very nicely in the upper RPM. Of course thats compared to stock. Of course for a used 100 cam I'm very happy with it for now
I'm Air Force, moved from Randolph last year. Hopefully going back next fall *** willing
Reply 0
Subscribe
