Where to Get Torks Bolts?
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
Anyone know where to get a GOOD set of Torks bolts? I got the TPIS Stainless Torks bolt kit when I redid the motor, but I stripped through them like butter.
Car: 89 Formula 350
Engine: 360 / HSR
Why would you want to keep the Torx bolts? I hope whoever designed them has had the pleasure of working on vehicles equipped with them.
I second the ARP allen head bolt suggestion.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by Jim85IROC
I've stripped more allen bolts than torx.
probly because you use mroe allen bolts then torx??
to be honest, niether of them should slip or strip if you properly engage the tool in them...... they should be able to take more stress then hex heads without stripping.
but if you put the torx bit in cockeyed and twist on it, you fugg it all up.... same for the allen head.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The problem lies in finding stainless hardware that's harder than a steaming turd on a hot day.
Car: 91 Camaro Vert
I'm pretty capable of properly engaging tools. I didn't start turning wrenches last week.
aahhh.. STAINLESS..... hehe, gotcha
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Hay Jim , I gave that TPISstainless bolt kit to my machienest / assembler ....... he said he HATED that kit ....he loved the torque heads better ........ He just shoke his head and said ......"you had to make it pretty didn't ya " . I just assumed it would be a good idea to get stainless hardware ....for the anticorosive feature .......shame it only came in Allen head
.....I have stipped them things too
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
Good Call on the ARP's. ARP is coming out with a TPI kit. P/N#1342004, but it is not out yet. They are awaiting the manufacture of (4) 70mm bolts, with no ETA. The kit has 46 bolts total. Pricing I got from ARP directly was:
Chrome Moly Hex $66.52/$84.55 Stainless
Chrome Moly 12 Pt $69.54/$103.96 Stainless
I explained my bad experience with TPIS bolts and was told that thier CM bolts were capable of upt to 170psi.
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
