3rdGenResource TPI Setup ???
Old Oct 29, 2003 | 03:56 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I am looking to make an offer on the 85 or 87 Z28 thats at a local gas station. The previous owner bought it for their son but he let someone break into it and bust the ignition switch. It was brought in the shop to have that replaced, but the owner never paid. It has an LG4 and an Auto. Hardtop. The body is striaght with two deep scratches with minor rust starting.
Its been sitting a while so the battery is dead, so pending it starts, I might make an offer of around $650. He's asking $800. Says I should be able to barely drive it home, runs real rough.
He made sure I understood that this is a project that'll probally need a $1500 to make a nice car outa it.
It has a carb that he says needs to be replaced and possibly the power steering pump too.
I want TPI for its efficiency and better MPG, but unsure if its a wise decision to swap.
Third Gen Resource has a TPI swap Kit for $450 that includes intake, runners, fuel rail, ECM, MAF, plenum, wiring harness, distributor and bolts.
What else would be needed to install this? Looks like I'll need gaskets and possibly some sensors??
Old Oct 29, 2003 | 06:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
So you're in it for 3grand (assuming 1500 put's it into shape).
Pretty sure you could find an L98 3rdgen already to go for that or less awithout having to do a bunch of work converting and replacing unknown as yet parts.
Old Oct 29, 2003 | 09:27 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
I am looking for "project" so yes, I want something to work on. I not looking for something fast and I not looking on keeping the car forever. Just to eventually replace my '94 a daily driver and either drop an LT1 into my my 94 or sell the '94 and get a GTA for fun.
Old Oct 29, 2003 | 09:45 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I wouldn't swap to TPI...too much of a restriction for the $$$...
Instead, swap the CCC carb and distributor out for a regular carb and distributor...
You can tune a carb pretty decently...it certainly isn't as easy as EFI, but if you have a budget for this car, you stay carbed...
Good luck,
Old Oct 30, 2003 | 01:37 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Good luck,
I would only keep TPI on long enough to pass emmsions then swap over to a superram or something like that. I would need all the tpi sensors and harness and stuff to do that any. This route seems more reasonable to do. It'll be a street car if I get it.
The non-cc carb and HEI sound like a fun swap, but I would have to pass emmissions so I think thats outa the question.
Does this kit come with everything I need to get up and running?
Old Nov 2, 2003 | 02:29 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Old Nov 2, 2003 | 02:32 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Probably best to check/confirm with the seller.
Old Nov 2, 2003 | 07:39 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Tell me what the seller says. I'd like to have a TPI setup too.
Old Nov 2, 2003 | 10:04 PM
hesgone2fast's Avatar
Car: 89 Trans Am GTA
Engine: 350 stock (big mods coming up)
Transmission: automatic for now (T56 coming)
You guys can find comlpete TPI setups on ebay for less than $500 dollars.
Might now be new, but they make the same job.
Old Nov 2, 2003 | 10:40 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
With ebay, theirs always the extra risk. Not getting your parts, getting faulty parts, or getting the wrong parts. And your stuck with it.
Old Nov 3, 2003 | 06:41 PM
Well, you bid on what you see. If you receive something wrong or some parts are misssing, you can always complain and get your maoney back, or even you can ask ebay to make a "more professional complain".
But I know, people usually want to sell things on poor condition, and they'll say "like new".
stalkier
Dec 6, 2015 11:25 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
