big problem need help
Old Oct 31, 2003 | 06:56 PM
rspeed7racer's Avatar
Car: 79 chevy malibu w/ tpi
Transmission: th350
my injectors arent firing when the car is warm ! the car will start with quick start then the injectors will fire . im slowly going insane. please help.......
Old Oct 31, 2003 | 07:49 PM
clippjr8's Avatar
bad ground in the inj circuit. i had the same prob for two years before i finally found it. i would drive to the store and the car would not start again till it was cold. the ground was close to the firewall under the hood. it was a red wire disconnected. good luck
Old Nov 3, 2003 | 09:06 PM
Transmission: th350
inj ground
is that ground coming from the computer or the fuse block? or is it coming right off the injectors? i put a 86 tpi setup into my 79 malibu and i hacked up the wiring harness for all i needed ( so i thought ) ! any help would be appreciated
Old Nov 3, 2003 | 09:51 PM
clippjr8's Avatar
I believe it is the ground coming from the computer. it is on the passanger side up along the firewall coming off the main wiring harness along with the injector wires. if need be, i can take a pic and post it for you tomorrow if that will help. just let me know, i would be glad to help.
Old Nov 4, 2003 | 11:01 PM
Transmission: th350
problem
no that wont help i looked for that connector but all i found was the est connector . i dont kno what ill do i didnt find any stray wires either. what color is the wire on both ends of the connector?
Old Nov 4, 2003 | 11:03 PM
Transmission: th350
problem
actually yeah a pic would help if you wouldnt mind. thanx alot
Old Nov 5, 2003 | 02:53 PM
clippjr8's Avatar
here is a pic for you:
Old Nov 5, 2003 | 02:54 PM
clippjr8's Avatar
like i said before, it is on the passanger side firewall in the small harness that runs along with the big harness from the ecu. hope that helps
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
