what valve seals where??
Old Nov 9, 2003 | 11:29 PM
grndmasnightmar
Guest
Posts: n/a
ok i have 16 o rings 8 valve stem seals that are circular with two metal bands around them and 16 umbrella seals. now what valve seals go on the intake and witch go on the exhaust? i think that all 16 get o rings but what about the others, is it 8 circles with metal on intake and 8 umbrellas on exhaust, or all umbrellas????
please help me.(and do the umbrellas get installed with the umbrella facing down or up) by the way the seals are carquest victors they look like rubber stuff. any one know.
Old Nov 9, 2003 | 11:41 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Umbrella facing down & they go on the exhaust.
Old Nov 10, 2003 | 09:38 PM
grndmasnightmar
Guest
Posts: n/a
soo....
why did they give me 16 umbrellas in a bag then. were they originally intended for all of the valves? and the circle stem seals with metal wraps are just better quality for the intake compared to the umbrellas. do i have the correct understanding of things?
also the umbellas on the exhaust...i am under the impreesion that the exhaust valves originally never has seals but its a good idea to put them on, thats why i am . so where do they go, u just have to take off the spring and junk and place it facing down on the valve seat or something? let me know if this sounds right its the first time im doing this.
thanks
Old Nov 10, 2003 | 11:33 PM
85TransAm406's Avatar
Car: 1985 Trans Am
not putting seals on the exhaust valves allows a little better valve guide lubrication, but does allow some oil seepage into the combustion chamber after you shut down your motor, causing a puff of smoke when you start your car (not always, but generally). The ones with the metal bands are a positive type and should be used if your heads are machined to accept them. I have Viton positive type on my intake valves and umbrellas on my exhaust.
Old Nov 11, 2003 | 12:37 PM
grndmasnightmar
Guest
Posts: n/a
humm....
well my tpi 350 is stock heads, will the positive seals fit the intake valves? and if not what do i use?
Old Nov 11, 2003 | 04:03 PM
Car: 1985 Trans Am
Stock heads accept umbrella style seals from the factory, which is what you would have to use. It's not neccessarily a bad thing though. Positive type seals can restrict oil flow to the valve guides, increasing wear. I only use them because of the increased cylinder pressure the seals will see with my upcoming turbo setup. I doubt you would notice a difference with either seal. When you install them, just think of how an umbrella works, and that's how you install them.
Old Nov 11, 2003 | 04:53 PM
grndmasnightmar
Guest
Posts: n/a
sooo
i should o ring all valves and umbrella seal intake and exhaust valves and send back the pos. seals?correct me if im wrong. and also how far down do i push the umbrellas on?
Thankyou for all the help so far :hail:
Old Nov 11, 2003 | 07:45 PM
Car: 1985 Trans Am
yes, o ring all valves and push the umbrellas all the way down till they stop. If you look close, they have to be all the way down or the spring retainer will just push it down when it is compressed. That is why you need machine work to install positive type, they are a little taller, and wouldn't give if the spring pressed against it.
Old Nov 13, 2003 | 09:08 AM
grndmasnightmar
Guest
Posts: n/a
thanyou
very much
Old Nov 13, 2003 | 05:00 PM
grndmasnightmar
Guest
Posts: n/a
forgot one thing
by the way the umbrella seals i got are car quest victors with 16 in a package , i can use all 16 which are the same part # on intake and exhaust valves. they are all the same size.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
