Diff between 85 vette 350 TPI and 88 T/A 350 TPI
Car: 85 Trans Am
Transmission: 700-R4
I need to know b/c I am hoping that when I put an 88 350 TPI into my 85 T/A with 305 TPI I can just use a stock 85 vette Prom (Until I learn how to burn my own proms) Def not going to be permanant but I am hoping to get good drivability out of it.
I already know that the heads on a vette are alum. but that is the only diff that I know.
Car: 1990 Formula
Transmission: WC T5
the vette has a oil temp that the F-Body does not that may throw a code because it is missing, however, beyond that if the cam is close to what the original vette had and the other original inners are the same I would think that it would work.
Car: 85 Trans Am
OK I have done some seaching and I found that Jim85Iroc had considered the same thing. But he ended up converting to the the 86-89 harness and ECM. But mabye he will chime in here and help me out with the info that he learned.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Your better off convertting to the 1227165 ECM, deleting cold start, and running $6E code.
Your even MORE better off converting to 1227730, deleting MAF and running $8D code.
-- Joe
-- Joe
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Car: 85 Trans Am
Sweet, from what I understand is that his car runs fine with 85 ECM and vette chip, and his engine is alot more modified then mine will be.
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Originally posted by ss85tadude
Anyone else know any thing about this?
for the first 6 months it was in. I later
did the '165 and then '730 upgrades.
mike
http://www.eecis.udel.edu/~davis/z28/
should still have a copy of an updated
'85 vette chip online.
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Here is some reading material about the diffs:
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
-Ozzy
-Ozzy
Sanjay
Aug 12, 2015 03:41 PM
