cam question
Old Dec 21, 2003 | 07:14 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
cam question
i was wondering if anyone could give me an idea or what they think the idle quality of one of these cams:
Lingenfelter 211/219-.530/.560", or
Lingenfelter 224/234-.496/.520"... with 1.6 ratio roller rockers,
(the rest of the motor is upgraded ECM, chip, etc, aluminum RPM centerbolt heads, fuel press. reg., shorty headers, and flowmaster or similar exhaust...
-possibly big mouth intake base with larger runners-not sure yet)
Old Dec 21, 2003 | 07:21 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Well here's my opinion.
In a 305, the 211 will have a lope and probably 14" or so of vacuum idle in gear, the 224 will be more radical with less vacuum.
Jake
Old Dec 23, 2003 | 04:54 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
You guys think either would run with a Stock 87 MAF (165) ECM? Someone else told me the 211/219 would be fine with stock computer. I am Looking for a simple way to add some horsepower to my 305 before I eventually replace it with a 383.
Old Dec 24, 2003 | 04:44 AM
JakeJr's Avatar
Axle/Gears: 3.07
With the 211 in a 305, you MAY be able to get away with just an adjustable fuel pressure regulator.
Jake
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
