NOID light flash?
Old Dec 23, 2003 | 06:14 PM
Hoss50's Avatar
Car: 1985 K5 Blazer
Engine: 350 crate w/TPI MAF
Transmission: 700R4/NP208
NOID light flash?
I am performing tests to diagnose my TPI no pulse to the injectors and I have a question.
I am applying 12V power to the purple (refernce wire) at the distributor plug and I am getting the Noid light to flash everytime I remove power, but..
It doesn't really flash bright. You can barely see the filament of the light turn red to start to flash and then go away. If you touch the purple wire a couple times fast the light will flash brightly, but not with just one touch.
Is this normal or what is the deal? Thanks
Harley
Old Dec 24, 2003 | 12:18 PM
ULTM8Z's Avatar
I'm not certain you're supposed to put 12V there. The GM manual indicates that the ECM only receives a 2.3V signal from that wire. Yikes, I hope you didn't damage the computer.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
