Gasket matching mounted heads
Old Dec 27, 2003 | 07:39 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You guys think its a terrible idea to gasket match heads that are allready mounted in the car?
I was thinking, close valves, tape off everything, match the ports, then vacume, then blow out really good with blow gun.
But some people think its a bad idea.
Any comments?
-- Joe
Old Dec 27, 2003 | 08:15 PM
OMINOUS_87's Avatar
You probably wont be the first to do it.
But not a great idea.
However it will be best to pull the heads and do the job right. Gasket matching is great but spending some time in the bowls will help even more.
Old Dec 27, 2003 | 08:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
not worth the chance of what could go wrong.
now if you pulled the heads, you might as well do a full basic port...
id either leave it alone, or pull the heads and do it right.
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If the heads come off, they're going on ebay. and I don't wanna yank the heads.. But I was thinking of getting rid of the TPI setup and getting something else. victor efi prolly, and figured it would be a good time to 1205 everything.
-- Joe
Old Dec 27, 2003 | 08:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the gains from porting the heads would be minimal...
IMO not enough to chance getting metal shavings in the motor....
not to mention, if yuo did, you'll be taking more then the heads off.....
Old Dec 27, 2003 | 08:31 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmn, let's see...little bits of castiron going up and down in the cylinders...versus 3 hp gasket matching the intake ports...
cast iron in the bores vs. 3 hp
Hmmnn...you be the judge.
Old Dec 27, 2003 | 08:34 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh well. That answers that. hehe
Anyone have a miniram of victor efi, pro-ram for sale? PM me.
-- Joe
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
89-S-dime
Aug 12, 2015 11:57 AM
Elliswon
Aug 10, 2015 12:33 PM
