Which bolts go where on TPI runners..... stupid question
Old Jan 13, 2004 | 03:56 PM
iroc_cragg's Avatar
I took the TPI apart to polish it, now im puttin it back together and dont remeber which bolts go where for the runners. Theres like 4 long ones and 8 short ones or so. Does anyone have a diagram or somthing that can help me place the bolts in the right holes. Thanks.
Old Jan 13, 2004 | 06:06 PM
llvll4l2c91350's Avatar
the plenum to runner bolts should all be the same size
the runner to intake bolts should be 3 sizes.
2 long
3 short
1 medium (the one you have to get from the opposite side)
at least that's how it is on mine.
Old Jan 13, 2004 | 06:20 PM
iroc_cragg's Avatar
ok sounds good, but which bolts go in which holes for the runner to intake, the medium ones for the opposite side but what about the other 5 bolts.
Old Jan 13, 2004 | 06:27 PM
look at the runner itself. should be easy to tell where to use the long ones and short ones from the casting.
Old Jan 14, 2004 | 12:07 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
it ain't that easy .....I got'm muffed up too ...... but I ended up shiming one with washers......just to drive it .
I spent 2-3 hours takeing them out and switching them back and forth ( on the bottom only ) .....it sucks trying to get them suckers in . But that was my first time takeing it off .....so I learned alot of stuff the hard way
Old Jan 14, 2004 | 07:00 PM
iroc_cragg's Avatar
any advice on where the bolts go, hahaha
Old Jan 14, 2004 | 07:39 PM
hmm,,,ok
you know where the medium bolts go...
the 2 long ones go between each tube (the short ones obviously wont go all the way thru), the rest go in the rest of the holes.
blue = short
red = long
Attached Thumbnails Which bolts go where on TPI runners..... stupid question-runner-bolts.jpg
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Are you looking to get in the lower intake to runner bolts, or just the runner to plenum bolts?
Old Jan 14, 2004 | 07:41 PM
1badrocZ's Avatar
Car: 1985 IrocZ
Engine: Carbed 383
also 1 medium bolt on each side that goes in from the opposide side of the other bolts...fairly simple
Old Jan 16, 2004 | 05:26 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
The easiest way is to install all the bolts into the runners BEFORE YOU try bolting them on.
Just look at how far the threads extend with the bolts inserted in the bolt holes. Juggle the bolts around until all the bolts have the same thread extension.
Visually, some of the locations on the runners have an extended boss; these call for longer bolts.
Jake
Old Jan 17, 2004 | 05:53 PM
Dyno Don's Avatar
Axle/Gears: 12 Bolt 3.73
These are the two bolts that dont have threads all the way up. There should be two bolts with a gap about 1/4" with no threads on it. Those are the ones that go underneath the plenum. Hopefully you understand what I mean.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
